04-09-2017, 11:38 AM | #1 |
Rep 35
CDV Delete on 2007, Remove or Replace with?
Hello, I'm going to do a bunch of maintenance soon and will probably delete the CDV. On my e90 with the same engine and transmission I just removed the CDV and simply reconnected the lines, I think it was mostly a plastic unit. There was no need to replace it with anything or drill it out. On the 5 speed Z4s I think it's a metal unit that needs to be replaced or drilled because the lines won't simply reconnect, but for the 6 speed cars, like my 2007 model, can you simply pull it out and reconnect or should I have a modified valve ready to go in. I plan to motive power bleed everything afterwards. Thanks,
04-09-2017, 01:20 PM | #2 |
Rep 204
I have the 06 3.0i N52 with the 6 speed. On mine, I just removed the valve (which was metal I think), and reconnected the lines. No attachments were needed.
You will need to bleed the clutch afterwards, I believe. -s |
