04-08-2017, 02:19 PM | #1 |
Rep 326
airbag SRS code on due to battery?
Just took my Z4 out of storage today... Put the battery back in, started it up fine, however, now I have the airbag SRS light on. Noticed a few threads across the forums for this issue, however, not due to the same circumstances as mine.
Can connecting the battery trip an SRS fault code? In my 8 years of zed ownership, hadn't seen this before. Only way to clear the code is dealer/indy shop/INPA software? Auto parts stores won't go near this code due to liability? I feel safe that I somehow caused electrical fault while putting battery back in and this is not indicative of a real problem. I'm presuming everything else in the car is fine, it's been sitting for 5 1/2 months.
the stable:
2003 BMW Z4 3.0i 2020 Mitsubishi Outlander SE 2021 Jeep Gladiator Rubicon |
04-08-2017, 03:39 PM | #3 |
Rep 326
Thanks for the offer! Granted I could use a nice road trip, I'm planning on an oil change at my indy shop this week so I'll probably have them read/clear the code. However, I'd like to obtain a proper cable & software so I could do this myself in the future.
the stable:
04-10-2017, 02:35 PM | #4 |
Rep 326
problem solved, undervoltage fault, cleared code w/ C310+ reader and I'm good to go now
the stable:
04-10-2017, 02:40 PM | #5 |
Rep 758
If you've got a terminal block on the driver's side of the battery well, check for tightness and/or corrosion there. That's the feed point for the SRS computer. Numerous posts about issues there causing an SRS light.
Top Down 365
04-10-2017, 02:42 PM | #6 |
Rep 326
yeah I'll go back and tighten/clean during my next free Sat afternoon
the stable:
04-10-2017, 09:23 PM | #7 |
Rep 326
should have said anything... light came back, no fault code read by the C310+, don't want to keep playing the game so into the dealer it goes, sigh
the stable:
04-11-2017, 10:15 AM | #8 |
Rep 1,107
If the code(s) you're throwing suggest over resistance in the airbag system I posted a DIY about cleaning the various connectors/contacts in the steering wheel airbag system. 1 hours worth of your time.
04-11-2017, 10:47 AM | #9 | |
Rep 326
I may backtrack to everything I've touched over the last couple of days; going to go back and electrical clean any of the connectors I bumped in the battery compartment as well as a couple under the seat dealer appt is set for tomorrow so this will be my last night of work
the stable:
04-11-2017, 11:56 AM | #10 |
Mechanical Engineer
96
Rep 1,025
keep us posted. i was just about to buy one of those C310+ readers, if it can't actually read the air bag codes properly i'll have to keep looking.
04-11-2017, 03:15 PM | #11 |
Rep 198
Hope you don't have the problem I had - fault in the ABS Module ( brake,traction and tire lights all went yellow ). All shortly after the original battery died .
Well I decided to check on mine today - the fairly new battery ( 2 years old ?) is just about dead to ?. Well I disconnected the one wire off the battery an am charging the battery now.?? |
04-11-2017, 08:29 PM | #12 |
Rep 326
Figured it out! Light is out now after clearing codes from a couple of sections other than the one related to SRS. The C310+ did its job, however, it's a little cryptic figuring it all out. Definitely keeping it now.
the stable:
04-13-2017, 05:40 PM | #13 |
Rep 204
