03-18-2017, 04:16 PM | #1 |
Rep 685
That moment when...
That moment when your project just goes down the tubes instantly. Was finishing up my vanos rebuilding and expansion tank replacement and was just finishing up connections when one of the hose clips went flying through the air. Not one BMW dealer has the hose in stock, well at least within a 100 miles. So now it sits dead in the water until one comes from who knows where. Seems kind of crazy that you can't just buy a clip or at least have the whole hose in stock. Parts are sure getting hard to get local for these cars anymore. Oh well probably should change the hose anyway, just a bummer is all. The point of this is to warn you to be very aware of those clips, they sure can fly.
03-18-2017, 06:20 PM | #2 |
Rep 2,704
That sucks
Just FYI, the clips do not need to be removed. Push in the clip to remove the hose.
03-18-2017, 06:49 PM | #3 |
Rep 685
03-28-2017, 08:20 AM | #8 | |
Rep 1,107
I really wish I had an extra garage or driveway space to take on a basket case project car. Something that wasn't running and didn't have to be put back together by the end of the day. |
03-29-2017, 09:20 AM | #9 |
Rep 623
I am working on my Polaris Jagged X, needed to have head work done. I was reassembling and found a loose bolt on the transmission to engine mount. I figured since it was loose I should loosen all of the other mount bolts and then torque them to the correct specifications and install lock-tight. One bolt would not move, the broken 15mm socket should have been a clue, second socket and the bolt broke... now I have to pull the engine to get the bolt out
Steve |
04-01-2017, 05:15 PM | #10 | |
701
04-01-2017, 08:35 PM | #11 |
Rep 685
Man don't you know that darn new hose managed to get a small slice in it. Have no clue how it happened but I saw poofs of steam coming from under the hood and sure enough a leak. Only thing I can think of is it happened while getting oil services done a few days ago, they were the last to have the hood open. I had saved my old house so I just air ground the solid clamps off and switched them to screw type instead, swapped the o rings and clips off the new one and I'm up and running again. I'm about ready to keep one of those hoses always in stock.
04-03-2017, 11:11 AM | #12 | |
Rep 623
Steve |
04-04-2017, 06:04 PM | #13 |
Rep 18
yep, after tearing apart the whole drivetrain to do a clutch replacement and then finally getting everything back together... won't go into gear. trans is out again.
