05-09-2012, 11:35 AM | #89 | |
Rep 784
Drives: 2011.5 E90 M3
05-09-2012, 11:36 AM | #90 | |
Rep 711
Any pics of the remote display?
|Evolve Airbox - Euro Headers - Strömung Exhaust - H&R Coils - 19" BBS CH-R| |
05-09-2012, 11:58 AM | #91 |
Rep 784
And here's the v1 plus my fasttrak
05-09-2012, 12:14 PM | #92 | |
Rep 12,570
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.07] |
No removal of pillars necessary, wires can be tucked in. I personally don't like wire taps - all personal preference. Never thought remote display was worth it. I don't want to have to look down or away from the windshield, especially if the radar's already mounted up there anyway. |
05-09-2012, 09:13 PM | #93 | |
Rep 704
Drives: '08 MC
Just finished reading the manual (yes go ahead and make fun of that), I'm already impressed and I havent even turned the thing on yet. the manual was extremely educational about enforcement 'trapping' techniques in general... this should be good fun to have in the car.
05-10-2012, 09:47 AM | #94 | |
Rep 784
I pulled the pillars because i wanted to be sure the wires weren't going to become untucked. It was also easier to route it into the dash that way.
05-10-2012, 10:35 AM | #95 | |
Rep 12,570
05-11-2012, 07:02 PM | #96 |
Rep 165
When I had my V1 in the roadster I mounted the remote display on the top left of the steering column, just under the guages. I pulled the trim piece off the dash, ran the wire out beside the edge of the trim and pushed the trim back on so there was virtually no wire showing. A little Velcro kept it in place. This kept the display right in front of me as well as the mute button.
For the mount, I fabricated on using a piece of 16" metal available at Home Depot/Lowes. I cut an "L" shaped bracket about 5" long and about 3" wide at the bottom of the "L". I then attached the V1 and now my Passport mount to the "L" part. At the top of the "L" I formed it to fit the contour of the top of the windshield to where the passenger side visor mounts. I pulled the visor mount off and screwed the V1 mount into that flat spot, then put the visor back on (the visor mount screw also secured the V1 mount). If you look real closely you can tell that the visor mount sits low the 1/16" thickness of the V1 mount, but you really have to know what to look for to see it. Now the detector sits just to the right of the rear view mirror out of my line of site. When I switched to the Passport 9500ix I put the remote mute button in my ash tray along with the control for the ZR4 Laser Interceptor. I found that I really didn't miss the arrows much even though they are a very nice feature of the V1. Here are some pics - sorry for the quality, I had to use my iphone. . . Last edited by jrich4411; 05-11-2012 at 07:11 PM.. Reason: adding pics |
05-13-2012, 10:31 AM | #97 |
Rep 704
Drives: '08 MC
Install complete, used the dome light tap method. Very discreet, cant even see it from the outside of the car when using the visor mount.
FYI the video posted in this thread on post #1 labeled "2005 bmw z4 radar detector install" references a blue and red wire that runs to the middle of the map light male adapter. That wire worked for that guy in the video, but it did not work for me. Granted I have an 08, not an 05, but it prob shoulda worked. And I stripped it right down to the bare wire too. Went back and tapped into the harder to reach purple and white wire as mentioned in other threads and that worked like a charm.
