      12-28-2022, 11:50 PM   #1
e90///M3
Drives: E90 M3
HELP recaro sportster
Hey guys
Does anyone know if Recaro Sportsters will fit with no issue? I want to be much lower than the stock seating position. Looking at MS floor mounts with recaro sliders. Also considered BK mounts but heard they are similar or barely lower than the stock position. Want to make sure before making any decisions.
Thanks!
      12-29-2022, 02:42 PM   #2
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
2022 BMW X3 M40i  [10.00]
2011 BMW 135i  [10.00]
2007 BMW Z4M Coupe  [10.00]
1991 BMW 318is  [10.00]
They will fit, see links below
https://www.zpost.com/forums/showthread.php?t=541566
https://www.zpost.com/forums/showthread.php?t=1172708
In regards to height, most brackets utilizing a slider are going to be close to stock height. Without the slider you can really get low (BK or otherwise) - may create an interference with the door cards however. There are a few folks that have tried the Planted Brackets, not sure how that height stacks up
      12-29-2022, 07:26 PM   #3
e90///M3
Drives: E90 M3
Thanks for the reply! I did see those threads you mentioned. Heard from some that u still can get lower stacked with sliders… hope anyone from experience can confirm
