03-12-2017, 01:28 AM | #1 |
Rep 9
How many times do you open/close your top?
Hey fam!
Just curious, how many times a day (or week) do you operate the soft top? I just purchased a Z4 and kinda paranoid of the roof malfunctioning even tho its like...brand new! Is there any recommendations to how many times you can use it a day? heh Thanks guys!! |
03-12-2017, 05:52 PM | #2 |
Rep 4,057
Open and close the top as you see fit and don't worry about the mechanism. It's very robust. If you park the car in a sketchy area, think it might rain before you get back or spot a pigeon eyeing your seats, just close her up and drop the top again when it's time to go.
03-12-2017, 07:31 PM | #3 |
salty cowboys fan
6158
Rep 3,406
Everyday it's not raining I'd only suggest catching it with your hand while closing to keep it from slamming down
she’s home! '22 M4 Comp xDrive
03-13-2017, 07:42 AM | #4 |
Rep 2,704
Once in the spring it goes down and once in the fall it goes up.
Don't drive it in the rain. The odd cool morning or evening I may wimp out and put it up.
scrammer421.50 |
03-13-2017, 08:47 AM | #5 | |
Rep 12,307
As long as it's over 55F and it's not raining, I'm using the car as a Roadster.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
03-13-2017, 10:09 AM | #6 |
Rep 779
None... my motors been dead for 3 years...
Actually I manually open it once or twice... I lied The one year I didn't garage my car we had like a lot of snow and it sat under snow for long time... motor died after that spring
-Roranji
03-13-2017, 10:28 AM | #7 | |
Rep 870
Drives: 2006 BMW Z4M Roadster
If you search for RA 54 34 217 you might be able to find it. I have a PDF of the installation process if you need it.
03-13-2017, 10:58 AM | #8 |
salty cowboys fan
6158
Rep 3,406
^^ I put those straps in a while back, they are indeed a pain in the ass to install. Even worse, the straps mount to the plastic inside the roof, which on mine eventually cracked off and became useless damn you 11 year old plastic
03-14-2017, 06:24 AM | #9 |
Rep 18,727
Never
03-19-2017, 05:02 PM | #10 |
///Multiple
2992
Rep 4,243
Before my 2006 Z4 M Roadster, which I bought in 2012, I had an S2000 for 13 years. I had to replace the roof at 10 years because the top started tearing where the folds were. I kept the top down all the time unless it was raining, which in San Diego is only a few weeks a year, including in my garage overnight. The auto upholstery shop that replaced my top told me that it is not a good idea to keep a convertible top down for long periods at a time because the fabric will tend to shrink, and the folds will weaken and tear, which is what happened in my case.
On my Roadster I always put the top up in the garage and any time it is parked. Maybe BMW uses better top material than Honda, but going on 11 years and my Roadster top is showing no signs of deterioration. YMMV.
03-19-2017, 05:52 PM | #11 | |
Rep 188
Thank you. |
03-19-2017, 07:47 PM | #12 |
Rep 355
probably a dozen times a year or so. it's always sunny down here,and it becomes the enemy(so to speak) after a while.
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
03-19-2017, 08:05 PM | #13 |
Rep 820
Drives: 2007 Z4MR silver grey
I bet I open and close my top 8 to 10 times a week down here is sunny and warm Charleston. I have been doing this since I purchased the car in 2011. No issues so far. It stays garaged and sees minimal nasty weather, so I'm assuming my motor is mostly dry and not rusted out, and the drains are clean. YMMV
03-20-2017, 01:08 PM | #14 | |
///Multiple
2992
Rep 4,243
If I used a hardtop, I would make sure that the top is completely clean and dry before installing the hardtop. Also, applying a good coat of wax in the area where the hardtop sits on the body.
03-20-2017, 05:17 PM | #15 | |
Rep 188
03-20-2017, 07:06 PM | #16 | |
///Multiple
2992
Rep 4,243
Here's some items from Roadster Solutions, but the hardtop hoists don't appear to be available from them any longer: http://www.roadstersolutions.com/page192.html#752
03-20-2017, 07:14 PM | #17 | |
Mechanical Engineer
96
Rep 1,025
03-20-2017, 09:17 PM | #18 | |
///Multiple
2992
Rep 4,243
03-21-2017, 05:05 PM | #19 | |
Rep 188
The MZ4 are very rare cars here and I believe that in the near future this TLC will pay off. I have closed parking on my work and my home and usually I move with my bike or my other car. I don't have a problem with the space.The hardtop I can get it for 600 euros. The used roof you can find it for more than 800 and not in good condition. |
03-24-2017, 11:48 AM | #20 | |
Rep 758
Top Down 365
04-01-2017, 04:58 PM | #21 |
Rep 3,004
Me too....
I catch it w/my left hand just before it contacts the windshield frame.
Racerbruce
