      10-04-2011, 11:27 PM   #1
asirvr4
Oman
38
Drives: '06 M Coupe VRS Blue
Z4M: 19x9.5 +20, 19x10.5 +22
19x9.5 +20 for Front
19x10.5 +22 for Rear
Will these fit my 2006 Z4 M Coupe?
      10-05-2011, 01:31 AM   #2
l4zy
l4zy's Avatar
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
2017 BMW M3  [0.00]
2015 BMW i3 REX  [0.00]
1995 BMW M3  [10.00]
2013 BMW X3 xDrive35i  [7.00]
depends on your tire size, ride height, and alignment settings. so to answer your question, they CAN fit but WILL they? that i cant say for certain. depends on too many factors and how much time you are willing to spend on making it work. it is definitely an aggressive setup though and you will most likely have to shave or roll your rear fenders and run -2.5 to -3.5 degrees of camber in the front. hope that helps
      10-07-2011, 01:16 AM   #3
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Rears will fit for sure. You will need slight fender roll, and some negative camber in the rear. And also, you won't be able to go wider than 275 in the back.
Fronts, I'm not sure of, but I'm willing to bet they'll fit with at least -3* camber, and no more than 255-width tire.
