      08-13-2010, 08:49 AM   #1
brandobot
Drives: 06 Z4M
Z4 3.0 18" tire sizes
Has anyone ran 225/45/18 in front with 255/40 in rears with any problem? Does the extra sidewall side make a huge diff?
      08-13-2010, 09:37 AM   #2
vachss
Drives: Z4 Coupe
Ask someone who's put Z4M wheels/tires on their non-M. Sidewall compliance will be greater and probably feel much like the 17's on a non-sport-package Z4.
But the biggest effect will be ~4% taller effective gearing. Your speedo will finally read just around accurately, but your acceleration in any given gear will be a bit reduced. Once you get up past 1st gear though this effect is largely negated though since you get to stay in lower gears to a commensurately higher speed.
      08-13-2010, 01:21 PM   #3
brandobot
Drives: 06 Z4M
Interesting, so by actually putting the 45 and 40 series tires on my 3.0, it'll correct my speedometer?
      08-13-2010, 02:23 PM   #4
vachss
Drives: Z4 Coupe
When I measured it against a GPS I found that my 3.0si speedo consistently measured 4% high. So going from 25 to 26" outer tire diameter should just about compensate.
      08-17-2010, 01:03 AM   #5
brandobot
Drives: 06 Z4M
Good to know, thanks!
Any reason why BMW would put a lower series tire when putting a 45 series would make the speedometer more accurate?
