      05-12-2021, 06:53 AM   #1
kyriian
kyriian's Avatar
884
Drives: 06 Black Sapphire Z4MR
2014 BMW X5  [0.00]
2011 Scion tC  [0.00]
Suspension Rattle
See if anyone may know what it is, it is also accompanied with vibrations at highway speeds.
I had the front end up last week, and i didn't see or feel anything's loose.
https://drive.google.com/file/d/1SAG...ew?usp=sharing - 1st recording
https://drive.google.com/file/d/1S9f...ew?usp=sharing - 2nd recording
Anyone also know what size is the OEM front control arm hex?
Revolution of our Times
I will return to the track, one day.
      05-15-2021, 05:00 PM   #2
rsutoratosu
Drives: Z4 3.0i
Really hard to tell.. the control arm the middle nut is 21mm. I had to go buy a 21mm for it. not sure about the end.. Ill go measure it in a bit..
-Roranji
      05-15-2021, 07:45 PM   #3
Our03z4
Drives: 2008 BMW Z4 3.0si Coupe,
Check your bolts on the sub-frame brace. My suspension was driving me crazy for weeks making strange noises and I found two loose bolts, fixed the problem.
https://www.ecstuning.com/b-genuine-...e/51717028433/
      05-17-2021, 06:54 AM   #4
kyriian
kyriian's Avatar
884
2014 BMW X5  [0.00]
I took it to a shop and finally traced the issue, should have been obvious
Top nut of my coilovers came loose
I had to take it off, and retighten it
