      04-27-2021, 10:00 AM   #1
B328iC
Drives: 97 328iC, 2003 Z4
E85 suspension differences
I have an E85 and I'm getting ready to refresh the suspension. What I don't know is there any difference between the E85 roadster with the M sport suspension and the regular E85 roadster.
      04-27-2021, 01:50 PM   #2
Steeler
Steeler's Avatar
2429
Shorter/stiffer springs, bigger bars etc
https://www.zpost.com/forums/showthread.php?t=1051184
      04-27-2021, 02:49 PM   #3
GuidoK
GuidoK's Avatar
10855
Drives: Z4 3.0i ESS TS2+
Apart from the mentioned above:
Shocks also have different partnumbers.
If there is a real difference in damping characteristics, I don't know.
      05-01-2021, 07:38 PM   #4
rsutoratosu
Drives: Z4 3.0i
What do you plan on refreshing ?
I have st xta coil over, new fca, stiffer fcab from the fly (check for sale section), bimmerworld adjustable end links, my sway bar is all rusted, going to sand it, clean it and spray, powerflex front sway bushing.
Still in process of installing, so I have everything apart. Also sand off rust in the sub frame and do a little touch up rust removal.
-Roranji
