02-04-2021, 02:51 PM | #1 |
Rep 2,866
Steering wheel shakes under braking
My MC had developed a shake in the steering wheel under moderate to heavy braking only. No shakes driving in any speed. Could a 2-piece floating rotor warp? If so, what can cause it to warp? If it is indeed warped, can the OE cross drilled rotors be turned/resurfaced?
I had already replaced the FCAB and got an alignment in an attempt to remedy the problem, but it still persist. Any insights or ideas would greatly be appreciated - thanks. |
02-04-2021, 03:46 PM | #2 |
10855
Rep 4,893
If you already replaced the FCAB in attempt to solve the problem, why didn't you place an indicator dial on the rotor in the process?
Takes 30 seconds or so (maybe remove the caliper with 2 bolts).And maybe measure thickness at the same time. Everything can warp and cause is the usual.
XMetal1134.50 |
02-04-2021, 06:20 PM | #3 |
Rep 2,866
It didn't occur to me, at the time that the a 2-piece floating rotor could warp so easily under mild street use. With that said, if it is indeed warp, is it advisable to turn (resurface) a cross drilled rotor? Thanks.
02-04-2021, 06:42 PM | #4 |
Rep 2,704
Can you recall a braking event that could have warped the rotor?
IE build up that much heat.
02-04-2021, 10:29 PM | #5 |
Rep 2,866
I don't recall such event that could generated that much heat to have warped the rotor.
02-05-2021, 06:16 AM | #6 |
Rep 484
Highly unlikely you’ve warped a rotor, especially on a street car. Pad buildup is more likely. To rule that out, do a brake bed in procedure to cook it off.
If replacing the FCAB did nothing, inspect the inner and outer ball joints. |
02-05-2021, 06:54 AM | #7 |
Rep 2,704
I have an upper strut mount going bad in my Cooper S.
Has been for a while. I get shimmy in the steering wheel under braking. FYI mount gets replaced tomorrow.
XMetal1134.50 |
02-05-2021, 08:22 AM | #8 |
Rep 3,004
This happened to me on my Z4MR; after assessing with multiple professionals, I was advised to perform 3-5 very hard stops from 60 mph; I chose a safe location and performed multiple hard brake applications (about 3 of them); the shimmy went away; it was explained to me that rotor and/or pad buildup can cause the shimmy; I was preparing to replace the rotors but sources told me it is very highly unlikely that the Z4M rotors warp, especially under non-track driving.
Racerbruce
02-05-2021, 10:26 AM | #9 | |||
Rep 2,866
Thanks everyone for all the excellent comments and suggestions - definitely gives me some things to look at and try. Very much appreciate it
02-06-2021, 08:30 AM | #11 |
Rep 516
Drives: E85 Z4M, F82 M4
Had a similar issue with my M4. I took someone's advice to do some conservative driving, lightly apply the brakes (just to the point that I could start to feel them making contact), and coasting with them applied for several seconds at a time, over a 15-20 min drive. The theory was to "gently" remove the build up, at lower temps, rather than potentially baking more debris onto the rotors. I did this a few times, over the course of a couple of days and the problem went away. Hopefully it's an easy fix for you too.
XMetal1134.50 |
02-10-2021, 11:58 AM | #12 | |
Rep 3,004
Any cause/effect updates??
Racerbruce
02-10-2021, 01:29 PM | #13 |
Rep 2,866
Nothing concrete yet, until I replace the rear rotors/pads but it's pointing toward uneven pad deposit. If I do a few light brakings, then it shimmy less and won't be too pronounce for a few days. Right now, it's difficult for me to do proper bed-in for the front brake because the front pads are a bit less aggressive compound than the rear, so my bias is a bit out of wack at the moment and that could also contribute to my uneven pad deposit for the front.
05-07-2021, 02:21 PM | #14 |
Rep 2,866
Apparently, you CAN indeed warp a 2-piece vented rotor on the street - I don't know how it happened, but it did Had my mechanic do a runout measurement and the rotors are warped. Also found out that you can't "turn" a 2-piece rotor...so new pads and rotors went in and smooth sailing again.
wdb4732.00 |
05-07-2021, 05:44 PM | #15 | |
Rep 3,004
Wowie!
Never knew this could happen w/street driving....have you had some significant negative G moments?? OEM pads or other?? I'm at 68K miles w/OEM pads and will have the Red Roadster serviced in the next month; how many miles on your OEM rotors before they were replaced?? If I may ask, what was the $ for parts and the $ for labor?? Regards Racerbruce
Racerbruce
05-07-2021, 07:09 PM | #16 |
Rep 2,866
I guessed some of those "significant negative G moments" could had happened on one of the many road trips/drives lead by "m3dragon" on here But I don't recall a moment where I was inhaling brake pads fumes
This issue is with OE rotors and Akebono ceramic pads. My Original pads/rotors were replaced with these at about 43k miles (currently sitting at about 64k miles). I wanted something that dusted a bit less than OE, so I went with the Akebono ceramic pads as I had great experience with them on my X5. The pads still have plenty of meat on them - free to anyone who wants them - local (Irvine CA) pick up only, though. This time, I just went with what my mechanic can readily get from his supplier, which is Zimmermann rotors and Textar pads. Out the door cost (Labor/Parts/Taxes) is just a shade over $800 for the front brake job. Last edited by XMetal; 05-07-2021 at 07:14 PM.. |
ToddBlack88595.00 |
05-08-2021, 07:02 PM | #17 | |
Rep 145
Have any part numbers for the rotors.
Current : 2007 Z4MC, 2010 F650gs, 2018 340i M Performance Edition, 2020 G310gs, 2009 128i
Past : 2001 325 cab, 2002 325xit, 1992 325 M tech ll appearance pack cab, 1990 325is, 1988 M3, 2012 328xit, 2009 M135i cab, 2016 M235i cab, |
05-08-2021, 11:27 PM | #18 |
Rep 2,866
Front Left => https://www.autohausaz.com/pn/34112282445
Front Right => https://www.autohausaz.com/pn/34112282446 I've used Zimmermann rotors on my X5 and they're good quality...so that's why I didn't hesitate to use them on the MC. |
ToddBlack88595.00 |
