01-17-2021, 05:32 PM | #1 |
Rep 102
Drives: 2006 Z4MR
Z4MR suspension refresh
Hey folks. Swapping original front springs onto Bilstein B6s, and have a question about how to position the spring on the lower pad above the strut plate.
Here's how the spring is positioned on the passenger side, which I have copied onto the new driver's side strut. Is this placement correct? |
01-17-2021, 07:16 PM | #2 |
Rep 2,704
If I remember correctly I bottomed the end of the spring against the stop on the isolator.
The spring coil began to rise at the step in the seat and rubber, so made sense to me to do it that way.
MadGus79.50 |
01-17-2021, 08:08 PM | #3 | |
Rep 102
Drives: 2006 Z4MR
When I tried pushing the end of the spring to the green arrow, the bottom rung of the coil hung over the side of the strut plate and the spring didn't want to sit down fully on the other side. Lined up as my pic shows it, it stays lined up all the way around. |
kaybat125.50 |
01-17-2021, 08:46 PM | #4 |
Rep 2,704
From Pelican parts diy page. Disregard the blue arrow.
Looks like the Spring is not bottomed out against the isolator stop
01-18-2021, 05:06 AM | #5 |
Rep 102
Drives: 2006 Z4MR
01-18-2021, 11:06 AM | #6 |
Rep 102
Drives: 2006 Z4MR
Should the new strut mounts turn freely when everything is reassembled? I was going to torque the top lock nut down on my passenger strut and noticed that the mount doesn't rotate.
Thinkin I messed something up on reassembly. Appreciate any thoughts... |
01-18-2021, 11:27 AM | #7 | |
Rep 102
Drives: 2006 Z4MR
But it is important to have the mount bolts lined up before you release the spring! |
02-05-2021, 08:26 PM | #8 |
Rep 110
How was the outcome? How do you like it?
racerbruce3853.50 |
02-08-2021, 09:02 AM | #9 |
Rep 102
Drives: 2006 Z4MR
racerbruce3853.50 |
02-08-2021, 12:02 PM | #10 | |
Rep 3,004
it makes such an incredible difference. I did this same conversion to Bilstein B6's and Eibach Pro-Kit springs in Q1 2017; I love the 3/4-7/8 in front drop and the 3/8-1/2 in rear drop; I also replaced the OEM front control arms with the high performance Lemforder ZHP performance front control arms and new OEM FCAB's and all new shock pads, guide supports, shock bump stops, etc; it is STIFF and handles like a freakin' race-kart....it is entirely flat in corners. I did this upgrade at 62K miles. How many miles on your Z4MR when you upgraded??
Racerbruce
02-08-2021, 01:08 PM | #11 |
Rep 102
Drives: 2006 Z4MR
61k on her at upgrade... couple hundred more now. :-)
02-08-2021, 02:43 PM | #12 |
Rep 3,004
Wowie!
We did our suspension upgrade(s) within 1K miles of each other.
Racerbruce
04-14-2021, 01:27 PM | #13 |
Rep 1,107
Madgus or Racerbruce, do you have the torque values for the fasteners involved in the front and rear shock replacement? I'd appreciate it if you could share. Much thanks.
04-14-2021, 02:30 PM | #14 |
Rep 102
Drives: 2006 Z4MR
04-16-2021, 03:24 PM | #15 | |
Rep 1,107
31 31 1AZ Strut pivot mount (3 nuts to strut tower): 34 Nm 31 31 2AZ Strut to pivot mount (1 large nut): 64 Nm* 31 21 4AZ The three bolts to hub carrier: 81 Nm** 31 35 5AZ End links connecting strut: 58Nm https://workshop-manuals.com/bmw/z_s...(m_r/page_895/ |
