08-13-2010, 09:37 AM | #2 |
Rep 815
Ask someone who's put Z4M wheels/tires on their non-M. Sidewall compliance will be greater and probably feel much like the 17's on a non-sport-package Z4.
But the biggest effect will be ~4% taller effective gearing. Your speedo will finally read just around accurately, but your acceleration in any given gear will be a bit reduced. Once you get up past 1st gear though this effect is largely negated though since you get to stay in lower gears to a commensurately higher speed. |
08-13-2010, 02:23 PM | #4 | |
Rep 815
When I measured it against a GPS I found that my 3.0si speedo consistently measured 4% high. So going from 25 to 26" outer tire diameter should just about compensate. Last edited by vachss; 08-17-2010 at 08:34 AM.. |
