02-08-2022, 06:05 AM | #23 |
11039
Rep 4,920
So what was the fault?
I don't know the 510 code reader, but a good code reader like inpa gives a number (either a P number or a specialized eobd number) and a description of the fault. That is key to how to solve the issue. That 'a fault' is present has no real value. I don't think the faults in the other modules can cause or register an engine shutdown.
02-08-2022, 06:53 AM | #24 | ||
Rep 2,706
02-08-2022, 03:52 PM | #26 |
Rep 12
93E7
Trouble Codes Description * SIM. Undervoltage And 12A FOXWELL Trouble Codes Description xGM Relay for central locking. double locking So I’m going to try to do a hard reset with the battery, then I’ll read the codes, then I will start the car up see if it will do it again, which I’m sure it will. And scan it again. Form there I will pull out the spark plugs and check if there is any oil on them like someone mentioned in the previous post. |
02-08-2022, 06:48 PM | #27 | |
Rep 566
https://www.bimmerforums.co.uk/threa...e-help.114148/ https://z4-forum.com/forum/viewtopic.php?t=96416 Is your airbag light on because both of those posts state airbag light was on with code 93E7. One suggestion was potential bad ground. If your battery was bad and you swapped to new battery, have you been scanning while hooked up to trickle charger or battery maintainer? I don’t think the central locking would necessarily cause power cut while driving. I once had mine go into anti theft mode which cuts fuel pump when cranking due to me taking longer to scan than expected and dropped battery lower than the car wanted and had to clear the anti theft. If it does that you wouldn’t be able to turn the car over until the anti theft gets cleared. But that also shows you how picky these cars are with their batteries. |
02-10-2022, 03:41 PM | #29 |
Rep 12
Yes it’s a stick. And no electrical is not shutting off. Just the engine for a split second then stays running there after it will continue doing this for entire ride, or if it’s on idle it will take about 35 minutes on idle start cutting off and then every 10 or so minutes it will continue cutting off until 3rd or 4th time before it finely stalls on idle.
02-10-2022, 05:17 PM | #30 |
Rep 160
Please read the following and focus on Ignition switch failure.
https://www.ultimatebimmerservice.co...gine-stalling/ Let hope it's simply this and not the wiring for the ignition. Your ignition switch is failing. after the first time it flickers off, it (the switch ) will get hotter and hotter and flicker off sooner and sooner, until the engine stalls. This will not cause a code. There are video's on youtube for doing the ignition switch and aftermarket switch's are not costly and on ebay. |
