      09-24-2022, 04:06 PM   #1
BimmerBren
BimmerBren's Avatar
Drives: 2015 BMW 328i GT, 2007 Z4 3.0i
Roof doesn't always open
Hey everyone! I'm experiencing roof opening/closing issues and I don't know what the issues is. When I go to press the open button, no lights turn on and the top does not open.
Yesterday the roof button was not working and the roof was not opening even when using the key fob. I suspected that the roof motor was flooded but the drains are not clogged.
Today, I get in my car and the top is working. The buttons light up and it opened and closed fine.
This afternoon it was not working again. Any idea what this issue is? I've had this issue in the past and I resolved it by resetting windows. This time the roof still does not work even after I reset the windows.
      09-24-2022, 05:03 PM   #2
Huz-Z
Huz-Z's Avatar
These cars have been known to do weird things if the battery needs replacing so that’s one thing.
You can also open and close the roof by putting the key in the driver door lock and holding in the lock or unlock position to open and close, respectively, I’m curious if the roof works properly every time that way.
      09-25-2022, 08:09 PM   #3
BimmerBren
BimmerBren's Avatar
Thanks for the response! The top is randomly working again today. This whole situation is very odd. I opened and closed the top by long pressing the unlock/close button on the key fob. If the roof doesn't open in the future I'll try your method. The battery voltage seems normal
      09-26-2022, 07:25 AM   #4
Huz-Z
Huz-Z's Avatar
You are welcome! More than happy to try and help! The factory set up in North America did not include the ability to close the roof with the button on the key as I recall so your car may have an after market module to enable that. If so, could the wiring for the module be the culprit, or perhaps the module itself?
      09-26-2022, 01:13 PM   #5
BimmerBren
BimmerBren's Avatar
I actually used Carly to code in the feature of closing the roof with the key fob lock button. I've had it coded for awhile and I don't think it would have caused the issue. Anyways, my roof has been functioning normally and hopefully it stays that way.
      09-26-2022, 01:45 PM   #6
Rafichicago
Rafichicago's Avatar
Drives: 2018 M5 2009 E63AMG Wagon
Have you checked out the micro switch inside the trunk where plastic parcel shelf touches it ? There's a metal piece that supposed to keep the switch pressed in. Make sure it's working correctly.
      09-26-2022, 07:13 PM   #7
JAS1169
Drives: BMW 2003 Z4
I totally agree.
The Micro-switch will cause a no light/no start which you reported. Your Micro-switch might be failing or simply tarnished and needs to be cleaned with contact cleaner.
      10-09-2022, 07:15 PM   #8
blufc3s
blufc3s's Avatar
Drives: 2003 Z4 3.0i
Where is this micro switch located? My top opens and seems to settle in place but the red light continues to flash. TIA
      10-09-2022, 07:20 PM   #9
Rafichicago
Its in the trunk there is plastic parcel shelf when you it your hyenas in and look up. Exactly in the middle of the trunk on its back wall. Photo attached
      10-11-2022, 10:39 PM   #10
jwolf
Drives: 135i M-Sport MT N-55 / Z4 3.0i
When it is not working, do you still hear a the electric motor run? A bad hall switch would cause a red light to pop up in the button area. So when it kicks off, look at the buttons. I am wondering if this is hydraulic or electric.
      11-16-2022, 01:12 PM   #11
blufc3s
blufc3s's Avatar
Thanks, sorry for the late response
The bolt holding the microswitch in place was loose. When the top was down the red light on the “down switch “ would continue to flash.
