03-21-2013, 11:25 AM | #1 |
Rep 21
manual mode ignore me
Hi buddies,
I have a problem with my Z4 3.0si automatic with paddle shift. When i'm in Manual mode, it sometimes shift as if it was in automatic mode. And sometimes, when i'm on sport mode(SD), it shit to normal mode (D). I made a video, i'll post it on youtube, so u could see. What is going wrong ? |
03-21-2013, 01:38 PM | #4 |
Why so serious?
141
Rep 743
Automatic, Manual, and Paddle shift? I thought that meant SMG. Do you have a clutch pedal? ()
03-21-2013, 02:07 PM | #5 |
Rep 9
I've got 3.0 Si with auto trans and it needs to have the shift lever moved to the left to enter manual mode. It will then hold in gear until stoping but also has throttle kick-down and upshift at redline. It is really just a gear holding feature for cornering and with torque converter locked feels like a manual gearbox. The sport button changes the shift points but is still full auto like in "D" unless the lever is moved over. Paddles are just for convenience and work secondary to the selected mode.
Hope this helps and make some sense! |
03-21-2013, 02:20 PM | #6 | |
Why so serious?
141
Rep 743
03-21-2013, 02:31 PM | #7 |
Rep 21
Hi buddies.
You're totally right Pete C, but you also have a full manual mode on auto trans, when the shifter is moved to left, it don't have to shift gears automatically |
03-22-2013, 07:34 PM | #9 |
Rep 415
Drives: 2005 z4 3.0
SMG was only available for '03 and '04 (maybe for '05 too) and was discontinued after that. The auto box (like mine) up to the facelift for '06 was just a regular auto with steptronic mode where you can shift up or down using the gear lever. In 06 they added paddle shifters to the auto box. In all cases, the auto box gets sharper response and later shift points with teh sport button engaged.
Is there a link to your youtube video?
2005 Z4 3.0 steptronic | TiSilver on Black | sport & premium package | 108s | Msport seats | wind deflector OMP strut bar | blacked out emblems | de-french-fried | sound gen | DIY aux input | custom speedo logos | stubby antenna | polished exhaust tips |
04-17-2013, 04:25 PM | #13 |
707
Rep 7,850
From what I gather in this thread, this is the SMG transmission, and very few (if any) of us have that transmission. If this is indeed the SMG, you might get more input from an E46 M3 crowd since the SMG box was used quite a bit on the E46 M3.
If I had to guess, I'd think the module/controller has issues, or the shift lever isn't triggering the right mode (manual vs. auto) which could be a contact/switch issue in the shifter mechanism. Since it works sometimes, and since modules using fail 100%, it may be a shift level/contact/switch issue. Access to a diagnostic tool to read any codes the ECU is recording would go a long way to helping you figure out where the issue is. |
04-17-2013, 07:59 PM | #15 |
Rep 12,565
It's not smg, smg was only available in early model Z4. Late model autos are similar to the tiptronic trans from the e46 non-m.
04-17-2013, 10:08 PM | #16 |
707
Rep 7,850
Ok. Did not know the SMG years.
Still think it's either a module or some kind bad contact or component in the shifter module/mechanism. That's my best guess. Diagnostic scan is best way to not guess. Last edited by Finnegan; 04-17-2013 at 10:26 PM.. |
