04-03-2016, 08:45 AM | #67 |
Rep 753
I have been running my Z4MC with 400lb springs at all four corners, Rogue Engineering RTABs, -2° camber up front with zero toe and factory settings in the back. For wheels and tires, 245 on an 8.5" rim up front and 275 on a 9.5" or 10" wide rim out back. These are on KW Clubsport dampers. I feel like a wimp with these rates compared to all you guys, but there I said it ?
The car is neutral and has a touch of understeer at the limit which gives me just that tiny bit of margin to collect things when they start to go. And I can fine tune with tire pressure differential and damper settings. The car would be super twitchy with higher rates out back and square tire setup; a Z4MC is not an e46 M3 or e92 M3 which are way more forgiving due to the long wheelbase and easier to drive as you sit close to the center of the car. |
04-10-2016, 11:23 PM | #68 |
Rep 1,923
Sound of car
04-18-2016, 03:22 PM | #69 |
Rep 1,923
just a small update....I went to the track this past weekend and the car felt amazing! I finally got my suspension dialed in!
My car feels very neutral now, and I dont have crazy oversteer anymore. the biggest difference was going with 1/8th toe in...it really helps with corner exit a LOT. thanks everyone for this tip Also, one thing that helped me was going with only +2 compression rear and +3 compression front...that killed my crazy oversteer too and it feels more neutral now. Now I am getting more and more confidence with the car to push harder and hope to lower another 1 2 second next time. now some pictures from this weekend. co-founder of stoptech and their race car miata engine 1300lbs.. a nice z4m race car. was doing very good in BMWCCA race and endurance too |
04-19-2016, 09:59 AM | #71 | |
Rep 2,747
04-19-2016, 11:36 AM | #72 |
Rep 11,668
+1 very cool.
Those trophies are great.
04-19-2016, 11:47 AM | #73 | |
707
Rep 7,850
I'm happy the rear toe-in settings helped, and we can add another data point to that set-up factor. I'm happy to hear that the suspension is finally getting to where you like it. Remind me, what spring rates did you finally settle on? This is been a really good thread for information sharing and gathering information about set up. |
04-19-2016, 07:43 PM | #74 | ||
Rep 1,923
my car is - 3.5 front and - 2.7 rear... my tire wear are very very good.
04-19-2016, 09:35 PM | #75 |
Down Under!!
1621
Rep 4,295
Alex, awesome mate that your getting the car sorted mate. very good car control and congrats on the trophies mate. (West coast represents!!! )
Powered by |
04-25-2016, 11:30 AM | #76 |
Rep 1,923
So I went to spring moutain near vegas this weekend, and I loved the track! didnt have time to upload video of the pb, but will do later on.
Just a quick update on maxxis RC-1...the first day, they are not very grippy, but the second day is amazing!!!! also got new rims with offset 28 and im using a 3mm spacer all around now instead of the 10mm here is a newbie video from my phone of my trip! and this is a close call almost crash into a s2k...that is a turn that you just tap the brakes to go full throttle for the main straight and he almost stopped the car! got very scared Last edited by AriuSen; 12-30-2016 at 06:11 PM.. |
04-25-2016, 04:29 PM | #77 |
1821
Rep 5,337
Did you guys stay at the condos on site? It is the best idea since sliced bread.
True ballah status.
04-26-2016, 10:57 PM | #80 | |
Rep 1,923
zero toe front and 1/8 toe in springs settings is 600/700, but i think its a little stiff for our cars....ideally i would try 550/650...need some time off to change my springs....i am having to run very soft compression due to my springs rates being stiff...if i stiffen just a little, my car starts skidding and i hate that. doesnt get the grip I want in high speed corners. I ran nt01 and now running maxxis rc-1....i ran with them 33 hot and with hankook rs3 35 hot Stock sway bar front and rear....I think they are stiff enough...have very little body roll. |
04-27-2016, 07:01 AM | #81 | |
Rep 11,668
04-27-2016, 07:11 AM | #82 |
Rep 26
04-27-2016, 07:28 AM | #83 |
Rep 11,668
Interesting!
the OP is running very stiff springs, removing the rear bar will help tame the rear end for him. I'm Not sure what you experienced or what other suspension you are running so your situation may be a little different. Generally a stiff rear bar adds to oversteer and a soft bar (or no bar) increases under steer. I'm currently running no rear bar and love it with my set up.
04-27-2016, 11:22 AM | #84 | |
Rep 1,923
I was going to try that, but I forgot to take my race ramp to do at the track. One question.....without rear sway bar, can I still intentionally break my rear loose by going on gas more? Cuz I like when on long sweeper a little oversteer to point and go. If the rear is too planted, I feel im slower on certain turns. |
04-27-2016, 07:31 PM | #85 |
Rep 11,668
Yup, still have on throttle oversteer.
It just doesn't snap as much.
04-28-2016, 11:37 AM | #86 |
Rep 1,373
Same here... no rear bar on my car. I had the GC soft bar set to its softest setting when i was running 525/650. When i went 600/750 i gained traction up front at the expense of the rear end. Spoke with Jay at Ground control and he said to take the rear bar out. Did that and I gained a bunch of rear end traction.
07 Z4 M Coupe AW/IR |
06-01-2016, 04:29 AM | #87 |
Rep 1,923
So today I went to bimmerfest2016 and they were running another bimmer challenge at auto club speedway.....very scary track since its an oval track and you enter the turn at about 145 to 150 mph and go down to 130 at the apex with the wall right next to you.
I ran before, but with the e92 and I had traction on cuz I didnt know how to drive rwd and car was all stock. This track is not favorable for z4m at all....high speed corners and lot of long straights...I think e92 m3 are the most favorable since its so stable on high speed and has lot of power. Anyway, I started running +5 comp +8 rebound and car felt so terrible so twitchy and so scary to push...any little input on steering wheel was scary....so for session 2 I lowered comp +2 and reb +13.....car felt absolutely amazing! was planted and no more crazy oversteer and I could push harder and harder on fast corners. I noticed that I need to run low comp and I always do best time....so I am starting to guess that this car was suppose to be run with around 400ish front and around 500ish rear cuz I wish I could use +5 comp, but my car never feels good in any track. this bimmer challenge was veeeery close one cuz everybody was doing 1:54ish, but I think senna got into my body and did 1:52.6 lol. It was a nice day for sure!! Car felt great...and last session started to play around a little, but this car is so bad to drift......e92 was super easy and fun! torque88 t-shirt company used my car before the event for some modeling lol video of the track day |
