      09-26-2008, 09:04 PM   #23
The__J__Factor
The__J__Factor's Avatar
Australia
88
Drives: ///M Coupe
Also im not trying to put down the kit in any way here guys, it looks 100% quality set up.
Just saying there is clearly room to work with here.
135i N54 manual
MR-S with a 2zz swap and mods Sold
EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold
Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold
      10-04-2008, 11:34 AM   #24
sales@ESSTuning
sales@ESSTuning's Avatar
391
Drives: ESS M3 / M4
Actually the ESS S54 CFR series is designed to produce massive mid range power. The SC sizing and overall system design is engineered to create a massive powerband and not just peak top end numbers like for instance a Vortech or Rotrex setup typically does. ESS tried to maximize the powerband without exceeding the maximum power goal. ie make the "strongest" 500/525hp kit possible..
To give you an example, attached is the current CFR 500/525/550 SC unit boosted up a bit more and compared to a conventional centrifugal unit on the same engine/day. These tests are done on a lowered compression CFR700 engine as it would not be possible to run the power anywhere near the 542WHP number on a stock CR engine on pump fuel. If the 542whp setup was geared down to make the same peak number as the CFR it would lack massively in the torque department, it even does now despite a 52whp top range advantage!
