      03-24-2018, 10:49 AM   #1
BCZ4M
Drives: BMW Z4 M
Exhaust Hub Tab and Cam Gear Bolt Check a Must
For those who have not yet upgraded their Vanos or at least checked their exhaust hub tabs and cam gear bolts, I suggest you do so soon. I just upgraded the Vanos on my new to me 06 Z4MC and discovered 1 broken tab on the exhaust hub and all 6 Cam Gear bolts backed out, one completely sheared the others almost sheared.
      03-24-2018, 11:39 AM   #2
Cyclops
Cyclops's Avatar
Drives: 09 E91 328i & 07 E86 M
on my to do list
2007 #1432 ///M Coupe Silver Gray - KW V3 Coilovers - AFE Intake - Strong-Strut Brace - Status Grupee Headers - Super Sprint Race Exhaust & Xpipe - 19" Avant Garde M359 - Stoptech 380 6 pot BBK - EPIC Motorsports Tuning ////////////2009 328xi M-Tech E91 manual 6spd
- Instagram ->@e91kiter
      03-24-2018, 12:43 PM   #3
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
VANOS
Inspected bolts, etc and the following completed during last yr's Insp II:
VANOS SOLENOID PACK SEALS S54
Removed vanos solenoid assembly and replaced vanos solenoid pack seal plate o- rings. Cleared faults. Cleaned residual oil. Bled cooling system and function tested vanos operation with no faults in DME.
Racerbruce
      03-24-2018, 04:14 PM   #4
Beedub
what miles are you guys at>>>???
my 06 is still only on 13k miles.... do i really need to tear this down at such low mile??? recommendations plz??
      03-24-2018, 08:28 PM   #5
Cyclops
Cyclops's Avatar
You seriously need to drive more.
SaltyNC369.50
      03-24-2018, 11:09 PM   #6
BCZ4M
Drives: BMW Z4 M
I'm at 69K. At 13K you're probably fine unless you track it. I would recommend getting something like the Beisan pump disk, which is designed to prevent exhaust hub tabs from breaking. The hubs are not cheap, cost me over $800 for it. Did my own labor, so it wasn't so bad but the work is time consuming, mainly due to access and would be expensive for a shop to do it. I was lucky, the broken tab was stuck in the pump and the bolts hadn't fully backed out. Not doing anything can get real expensive.
      03-25-2018, 03:14 AM   #7
StickMon
StickMon's Avatar
Drives: 2006 MR
I bought mine with 39k miles and it had 3 bolts backed out and 3 sheared.
Exhaust tab broke at about 75 k miles.
Replaced the entire Vanos, timing chain guide, and rod bearings at about 125k mikes.
Closing in on 175k miles.
You need to drive yours more.
      03-25-2018, 12:37 PM   #8
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
did you do the rod bearings yourself?
      03-25-2018, 04:14 PM   #9
Beedub
lone parent, business owner..... i barely have the time to sit down and catch a breath never mind driving a weekend car.... i'm just glad i've been able to keep it....
Sounds like even at these miles its worth looking into the vanos issues, alittle nervous to jump into it DIY but....... im always up for it, how difficult is this?? i can comfortably to the VC checks for reference.
      03-25-2018, 11:22 PM   #10
StickMon
StickMon's Avatar
Drives: 2006 MR
Nope. Took it to Lang.
I can do a lot of stuff myself, but mostly up top.
My garage is too low to install a lift, and I couldn't see doing the rod bearings on jackstands.
You're local. Andrew told me he likes to do rod bearings.
      03-31-2018, 02:29 AM   #11
jdoublehcubed
Mechanical Engineer
He did my vanos exhaust hub about 2 years ago, top notch work. That's probably the only place I would trust to do bearings in LA. What did it set you back?
Fingers crossed, my lead levels are still quite low, so I'm hoping that job stays far into the future.
      03-31-2018, 08:00 AM   #12
WhatTheFetch
WhatTheFetch's Avatar
93
Drives: 07 Z4 M Coupe
2019 Bullitt  [0.00]
2015 BMW M3  [0.00]
2018 Camaro 1SS 1LE  [0.00]
I'm having my Vanos rebuilt with the Beisan rattle kit, upper chain guide and upgraded pump disk this month. Also upgrading the cam bolts as well as a valve job. i will report back with the condition of the cam bolts and hub. Fingers crossed its okay! I bought my Z4MC last july with 41,900 miles, I have 43,700 on it now..
I'm also curious about the approximate cost of having the rod bearings done. I know that will need to be addressed down the road.. When I do the Vanos/Service I'm going to send an oil sample to Blackstone.
      03-31-2018, 08:41 PM   #13
StickMon
StickMon's Avatar
Drives: 2006 MR
Survey says $1600-$1800 for rod bearings.
      04-01-2018, 01:34 AM   #14
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Yup. Material cost (bearings) went up this year. Relatively speaking very cheap compared to a motor rebuild or new motor.
      04-01-2018, 09:41 PM   #15
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
Vanos overhaul isn’t difficult, especially with Beisan’s guide which is excellent. Rod bearings aren’t so tough either (even on jack stands ), but you’ll have to roll your own guide via TIS, E46 M3 forums, and the nice folks here
Depending on what tools etc you already have, you can DIY bearings for ~$8-900 iirc
