03-08-2016, 10:35 AM | #1 |
Rep 1,923
OEM z4m e86 radio amplifier question
Hi,
I sold this item on ebay, and I wanted to confirm if this fit z4 as well? He is asking for a refund because the amplifier doesnt have antenna connector? What does he mean by that? thank you |
03-08-2016, 11:42 AM | #2 |
Rep 1,772
Drives: 2007 Z4M Coupe
I have a Z4 amp somewhere I'd be willing to swap with yours.
03-08-2016, 11:43 AM | #3 | |
Rep 1,923
03-08-2016, 12:12 PM | #4 |
Rep 406
He's probably referring to the coaxial connection that ...on my car... Is required for the Carver 10 speaker DSP high end radio/amp system.
That said... If he didn't do his homework and ordered an amp that didn't fit... Alternatively... Did you post the amps stock number? If you didn't then he has a case for a refund/return.
Sent from my smart phone...
03-08-2016, 12:27 PM | #5 | |
Rep 1,923
03-08-2016, 01:42 PM | #6 |
Rep 406
Nope.... He's looking for a specific amp that has that connection. And unless the amp under consideration for swap has that specific connection and is an identified replacement amp for that use (for his car).....I'd refund him his money and re advertise the amp and include the stock number. Different setups require different amps and not all are compatible...
03-08-2016, 02:32 PM | #7 |
Rep 1,772
Let me see if I can find the amp and post the part number.
03-08-2016, 03:39 PM | #8 |
Rep 406
Will need purchasers last 7 VIN numbers....and have them use realoem to determine the amp/replacement amp required.
