03-21-2018, 09:18 PM | #1 |
Rep 3,004
Historical condition of small oil leak at head / block area....
During today's scheduled oil change using Castrol the OEM spec 10w/60w, it was noted that a very small oil leak was occurring at the head / block area. There is no compression leak - no other issues, and the leak is VERY small. My beloved Z4M Red Roadster has just over 65K miles....has anyone else experienced this?? The repair requires head gasket replacement - I was advised to monitor and assess, and not replace the head gasket at this time....your thoughts.
Racerbruce
03-21-2018, 09:48 PM | #2 |
636
Rep 3,124
You sure it's coming from there?
I thought that years ago and it was just my CPV. Any chocolate milk on the bottom of your oil fill cap?
03-21-2018, 10:02 PM | #3 |
Rep 3,004
Oil leak location??
My tech stated that this is a common S54 oil leak due to the head drains it's oil at the outside are of the head, promoting this very small leak condition??
Racerbruce
03-22-2018, 01:11 PM | #5 |
Rep 3,004
Head are oil leak
Great - thank you.
Racerbruce
03-22-2018, 01:52 PM | #6 |
Rep 870
Drives: 2006 BMW Z4M Roadster
They make one out of Viton. You can probably find it googling, but if not, I'll try to find the link for ya.
03-22-2018, 01:54 PM | #7 |
636
Rep 3,124
They're on Amazon now (what isn't).
https://www.amazon.com/BMW-S54-CPV-r.../dp/B00JD5V02K https://www.amazon.com/Service-Viton.../dp/B01ASP3XL4
03-23-2018, 01:49 AM | #9 |
Where Does He Get Those Wonderful Toys?
94
Rep 290
03-23-2018, 12:59 PM | #10 |
Rep 97
If its at the front of the engine, ac-compressor-area and along the sump it can be the vanos steel gasket or the timing chain tensioner gasket.
perdidit in spatio
18" Arc-8 - Michelin Cup2 - KW V3 - GC camberplates - RE trans mounts - VT engine mounts - Vorshlag RTAB shims - RPi - stubby - CDV del |
03-26-2018, 08:45 AM | #11 |
Rep 1,107
One final add. When I replaced the o-Ring with the Viton one I also changed the CPV. It's cheap and since it's a slotted screwdriver head (??) I figured newer would be better.
03-30-2018, 01:55 PM | #13 |
Rep 453
Drives: 2007 Z4M Coupe
I discovered a leak last fall, at first I was worried it was from the head gasket but upon closer look I believe it's the VANOS gasket. So this summer I'm doing a VANOS overhaul which will include a gasket replacement.
