04-06-2017, 09:05 PM | #1 |
Rep 20
Was backed into. Only did damage to my left front corner. Only cosmetic. I'll attach a pic. Already ordered the fender and bumper. My headlight functions properly but it did shatter the lens. Can I replace the lens or am I looking at a whole new assembly? Also I can't a used left headlight any where. What are my options?? I'm worried if I get a brand new one it'll be way nicer than my old right one. Thanks guys!
Sorry for the dark photos.. Makes the headlights look black. They're not. |
04-09-2017, 09:06 PM | #2 |
Rep 12,565
You need to get a whole new assembly.
05-15-2017, 04:58 PM | #3 |
Rep 23
you'd need the whole assembly, but you have to swap over the ballast, control unit, and possibly bulb depending on what you have. if you can find me a part number i can see if i have one for you. it might have a broken tab or two and some scratches, but if youre looking for a quick/temporary/cheap fix it could work. definitely keep it out of the rain and moisture if possible because the components pretty much cost as much as the headlight itself. if i do have mine, it would be a z4m bi xenon steel one
and if you have full coverage and/or uninsured motorist you should file a claim. the damage is still a couple thousand. also, it would be good to have a report on file because there are cases where the person who hit you could file a claim against you later on saying you rear ended him and left the scene. i believe the statute of limitations is 2 years in okc so they could open up a case anytime within that time frame. Last edited by kdanny626; 05-15-2017 at 05:20 PM.. Reason: more info |
05-16-2017, 07:06 PM | #4 |
Rep 29
This guy is parting out a 2004 E85. I've bought a few things from him and it's been a pleasure.
He has each headlight assembly for sale for $350 each OBO: https://losangeles.craigslist.org/la...127758288.html So, hopefully you might be able to save some money buying these used in conjunction with filing the claim as suggested by kdanny626. Good luck! |
