08-30-2011, 09:18 AM | #309 |
instagram 997turbotom
279
Rep 7,377
Return those headers, not worth the hassle of the repair. I don't think they're even repairable back to 100%
do you want me to lend you my stock headers in the meantime?
08-30-2011, 11:24 AM | #310 |
Rep 476
K so I got in touch with the seller, who is very surprised at the dents and not only insists they weren't there when he shipped them, but offered to give me a refund if I send them back. That's about as well as I could have hoped it to go, but unfortunately I still see ABSOLUTELY NO WAY this type of damage could have been incurred in shipping. The box was externally in good condition (no obvious damage), the entire thing was filled with packing peanuts, and each header was fully wrapped in 2-3 layers of the thick kind of bubble wrap. If you look at the damage, in particular there is one dent I don't even understand occurring if it were dropped, like the flat bits imply.
I did get a photo before they were shipped, but it is only a 320 x 240 iPhone photo in which they look fine. Upon extremely close inspection I can't be certain whether or not they were dented in the photo. Any more opinions on if they are reparable? Shipping was like $80 for the sender, and I would obviously have to push back the install date even further if I have to source the headers again. Roffle, thanks for the offer but I actually still have my USDM headers--maybe I should just use the fuckers and completely abandon the catless / sensor relocation strategy? At least the cracked windshield (http://www.zpost.com/forums/showthread.php?t=578204) is being replaced with OEM on Wednesday. Also, today the "8PSI" pulley shipped out from Norway, amazingly scheduled to arrive Sept 1st. |
08-30-2011, 11:30 AM | #311 |
279
Rep 7,377
To repair them, they may have to pack them with sand, heat them, and then somehow pound on them until the sand evens things out. Or they may use a hammer somehow. Anyway, it would probably weaken the overall structure, and the un-even mounting point is another thing that may never be perfect
I think the seller was just hoping you were an idiot
08-30-2011, 11:40 AM | #312 |
279
Rep 7,377
If you have the time/patience/skill, I'd try running it with stock headers. I mean... what if ESS is wrong, and the headers are not causing the deceleration issue?
08-30-2011, 12:01 PM | #313 | |
Rep 476
I wish all the damn hardware to do the header swap wasn't so expensive. This is the second set of torque-to-yield bolts, gaskets, etc I've ordered and I don't really want to swap the headers a THIRD time if I were to try the USDM ones again. Honestly as I've said I would not be very worried about losing some power, but am concerned about all the heat retention under the hood. I'm certainly tempted by the fact that I could do the header swap myself this weekend with the replacement hardware that I rush-shipped to get the CSL headers in. It would certainly be easier than my first attempt at the job doing the AA headers, but still a huge pain in the ass. It's probably best to hold off until I have some CSL headers that are suitable to put on the car. Anyone want to make an argument for why I should stick with the USDM headers? I could be a sorta-green-friendly supercharged car! lol. |
08-30-2011, 12:13 PM | #314 |
279
Rep 7,377
screw the environment! No reason to leave 20rwhp on the table
I'd think you can easily re-use the "consumables" for the install, since they're so fresh
08-30-2011, 01:09 PM | #315 |
Rep 5,328
arhhhh probably alittle politically correct but i cant ever say screw the environment, i think we all have a duty to look after our world otherwise it wont look after us.... hurricane irene anyone????......
Relly though catted headers make no sense with this car imo you'll loose good power, catted headers in this application with boost im guessing would add a good amount of underbonnet heat. the design of the thin wall csl is awesome, very light and very free flowing, would you like me to source something this side and get it over to you??? i do agree though what if the headers arnt the problem??? personally id leave that as a last option, especially as others have different branded headers working with the vt2-500.
08-30-2011, 01:13 PM | #316 |
Rep 5,328
wierd thing is soo many CSL headers that are removed have this damage to them or very similar damage, im guessing removing them isnt easy, its always on the last runner.
08-30-2011, 01:16 PM | #317 | |
Rep 476
Are Roffle and you suggesting that I try the USDM ones because if they don't solve the hesitation, purchasing the CSL ones and doing the Section 1 modification was pointless? While that's true, doing the header swap a second time is probably overall more work than the fussing around trying to find a new set of CSL headers, sending back the dented set, and then trying to sell the AA headers. I'm really not sure what to do. About this damage being common on CSL headers--interesting because my shop also just told me that they've seen very similar damage before as well, and in that guy's case he also had to send them back and source different ones. So far no one has told me "oh yeah man, np, we can fix those". |
08-30-2011, 06:01 PM | #318 | |
Rep 2,231
http://m3forum.net/m3forum/showthread.php?t=248739 Last edited by eunosracr; 08-30-2011 at 06:17 PM.. |
08-30-2011, 07:01 PM | #319 | |
Rep 476
I agree the flat spot looks almost as though it was supposed to be that way. BUT--the CREASED area does not look like something that could reasonably have been done during manufacturing. Even more obviously, the triangular flange is bent and there is no way it could sit flush. The seller went to the point where he shipped the headers, and apparently the attendant who packed them /without the seller's supervision/ seemed nervous as he inquired about the damage. He denied it, but it seems pretty clear that the damage was done during packing after they were dropped off. The seller says the packing guy was a college kid and he'd rather eat the loss than risk the kid's job over the matter--a noble position, but I'd rather see the shipping company pay for it. Anyone else have pictures of CSL headers that have these creases and flat spots on them? |
08-30-2011, 07:18 PM | #320 | |
Rep 2,231
08-30-2011, 09:04 PM | #321 | |
Rep 476
My metalworking friend got back to me and after examining the headers in person, believes it would take a "master-level" worker to properly fix the damage (which he doesn't consider himself to be). The steel is just too thin and it would likely be punctured or torn during a repair. krnnerdboy has come to the rescue with a pretty unbeatable offer on some non-CSL Euro headers that appear to be in good condition, and since he's located in Southern California, they shouldn't be as expensive or take as long to ship. I will however have to postpone the header swap until next week. I thought about reinstalling the USDM stuff this weekend, but really don't think it's worth it because Euro is where I want the setup to be and waiting just 4-5 more days will allow that to be done all at once with fresh hardware. If they aren't really the cause of the hesitation, at least I will be running completely ESS-approved equipment. |
08-31-2011, 06:24 PM | #323 |
Rep 476
OK, wow. Krnnerdboy didn't charge me a dime for shipping (on top of the bomb $650 price for the non-CSL headers), yet made sure they will arrive by Friday (2-day shipping)! Truly fantastic!
My tentative plan in light of this: - install them myself this weekend, saving several hundred bucks in labor - wait for the EGT bung to arrive next week, then have the USDM Section 1 modification and sensor relocation done all at once by the shop Meanwhile I got the damaged set boxed up and shipped back to the sender, who is going to use them for his own car...I guess we'll find out if the damage results in a burnt exhaust valve after all... |
08-31-2011, 06:49 PM | #324 | |
Rep 784
Drives: 2011.5 E90 M3
As for the catless problem, do you have an "understanding" worked out with your smog guy? |
08-31-2011, 06:56 PM | #325 |
Rep 476
I will handle smog when the time comes. I'll have USDM headers in functioning condition if necessary, but have gotten a Supra that shouldn't have passed visual inspection cleared--twice.
09-01-2011, 05:27 PM | #326 |
Rep 5,328
lots of clips for you guys from my track work today, check media/pics section :-)
09-02-2011, 09:17 PM | #327 |
Rep 476
Got the replacement Euro headers today--wow, something went right! I was expecting the FedEx guy not to leave the package or something despite my note pleading him to leave it (I wasn't sure if it required a signature). On the other hand, BMW will have had my car for 72 hours by the time I can pick it up with the new windshield tomorrow morning (it was supposed to take 24).
I also received the "8PSI" pulley today. Beedub, I'm wondering if this pulley is the same size as yours or possibly even smaller...it is about 3.1in/78mm. |
09-03-2011, 02:21 AM | #328 | |
Rep 5,328
09-03-2011, 10:42 PM | #329 |
Rep 476
New Euro headers are on, and most of the nuts tightened down, but still don't have the reinforcement plate or air pump back on. I'm waiting for an answer here: http://www.zpost.com/forums/showthread.php?t=581216
Hopefully someone responds by tomorrow morning because I really want to finish the job and give the car a thorough test drive...but if I reinstall the axel reinforcement plate and have the O2 ordering wrong, it will be extremely difficult to swap them without removing the plate, and I have only one set of new torque-to-yield (one time use) bolts. |
09-04-2011, 03:08 PM | #330 |
Rep 476
Headers installed, out right now after my first drive. There is an SES light but no limp mode. Will read codes when I get home and further test hesitation on the way up the hill.
