      10-11-2022, 02:33 AM   #1
Phatty
Phatty's Avatar
11
Drives: Bmw E86
FS - Extended Leather Door Cards, Saddle Brown (Deployed Airbag Driver's side)
was from a parts car. Driver's side airbag deployed so the colored insert is ripped. This section is glued in place so you can just swap your existing panel onto it for that sweet extended leather door card. Also on the top edge of the driver's door card has the leather (about 2"-3" along the top needs re-glue).
Passenger side is pretty much good to go, small scratch by the window switch (see pic).
aside from the above, they are in good condition. I already have extend leather cards so i don't need these, thought i should pull them before they get weather damaged.
EDIT: photos of driver's side with area that needs repair.
the area between where my finger is pointing to is the area that needs re-sticking. the area that needs attention is just above the first seam of stitching. Other than this area, the rest of the door card is in good condition other than the colored insert.
Circled the areas that need attention in yellow on the above two pictures.
Do not want to ship these, $300, local to socal 626 area.
      10-14-2022, 08:48 AM   #2
F360C
Drives: E86 S54
Do you have the center console extended leather pieces also?
07 Z4 M Coupe AW/IR
      10-15-2022, 09:48 PM   #3
Phatty
Phatty's Avatar
11
Drives: Bmw E86
Nope. Just the door cards and seats were extended leather.
      10-16-2022, 03:26 PM   #4
F360C
Drives: E86 S54
Pm sent
07 Z4 M Coupe AW/IR
