      09-26-2020, 04:20 PM   #1
Titaniu//M
Titaniu//M's Avatar
48
Drives: M3
Porsche 996 Brembo Calipers for E46 M3/Z4M - Painted Red
USD 1,400.00
SOLD
Up for sale is a set of 4 refinished Porsche 996 brake calipers made by Brembo. These calipers, along with Rally Road adapter brackets, Rally Road brake lines and ZCP front rotors come together as an affordable BBK upgrade for the BMW E46 M3 and Z4M. Calipers are ready for installation on a Z4M, no additional work needed.
Part numbers for the calipers
• 996.351.426, 996.351.425 (front)
• 996.352.422, 996.352.421 (rear)
These calipers were sourced from a wrecked Porsche with 37,318 miles. They were inspected, cleaned and tested. In addition, the front calipers have been machined 5.5 mm and the rear crossover lines have been switched from left to right and vice versa. Calipers were not rebuilt, as the testing showed that all seals were fine.
The calipers are painted, not powder coated. I did the paint myself, and it is respectable, but not perfect. Some small flaws are present throughout, but will not be noticeable once the brakes are on a car. The insides have a bit of a rough texture. Paint is heat resistant and has been cured in an oven, but is still not as durable as the original Brembo finish. I am not a professional but am proud enough of this paint job I would put these calipers on my own car. If you are a perfectionist a powder coated set would be more ideal for you.
Approximately $1k of additional stuff is needed to complete the conversion in addition to these calipers, $1500 if you would like ZCP rear rotors (stock E46 M3 rotors will work). I have compiled a shopping list and can send this to the buyer.
I will include a nearly new set of 996 brake pads, used caliper hardware and pad wear sensors. In addition, I will include a set of 987 Boxster front pads which you can put in the rear calipers for full rotor contact.
Asking $OLD shipped for the calipers, local pickup available in Columbus, OH.
Listing is for calipers only, does not include adapter brackets, brake lines or rotors.
2006 BMW E46 M3 Coupe - 6MT - Titanium/Imola
1999 BMW E36 M3 Coupe - 5MT - Estoril/Dove
2000 Honda Civic Si
2011 Toyota Tacoma PreRunner T/X TRD
      11-02-2022, 05:59 PM   #2
Compactive
Drives: 09 335i, 95 318ti
DM sent
      11-02-2022, 07:06 PM   #3
E86Z4MC
Drives: Z4M Coupe
I'd be interested
      11-02-2022, 07:21 PM   #4
Titaniu//M
Titaniu//M's Avatar
48
Drives: M3
