      06-11-2015, 09:11 AM   #1
///S55
///S55's Avatar
Drives: 2015 M3
Exhaust tips
Doing a stock muffler bypass with a butterfly valve but would like to replace the 2.5" stock exhausts.
Where would one find some 3" tips?
Add1cted
      06-11-2015, 01:24 PM   #2
UntzUntzUntz
UntzUntzUntz's Avatar
Drives: 21 M2 Comp
I got mind through eBay and cooped it with Magnaflow mufflers. Looked everywhere for the seller but couldn't find him. Instead I found someone else that has an identical tip. I found them through eBay but here's the companies direct website:
https://www.skspeed.com/ProductDetai...D=ETCDT-25083L (Left)
https://www.skspeed.com/ProductDetai...D=ETCDT-25083R (Right)
They also have one with a 3" inlet if you're planning on getting a large outlet muffler with it.
      06-29-2015, 12:17 PM   #3
UntzUntzUntz
Drives: 21 M2 Comp
I was also on the M5 forums and came across this:
http://www.m5board.com/vbulletin/par...pipe-tips.html
It's pretty damn expensive but also pretty damn sexy.
      07-04-2015, 11:07 PM   #4
2286
You should check these out. Stainless steel, double wall, 3" OD and I think 2.5" ID. A lot of E46 M3 owners switched over to these and had great results. Pricing is really reasonable too!
http://www.emnotek.com/p-256-stainle...aust-tips.aspx
      07-27-2015, 03:28 AM   #5
Nige Powervalve
Drives: Audi TTRS BMW Mini Cooper S
Nice trims - similar to ours, we have ours raked at 15 degrees ;-)
      07-28-2015, 02:54 PM   #6
DEG
DEG's Avatar
68
Drives: 2007 Z4 MR
I have the same tips. Here's a pic for you.
      07-28-2015, 11:29 PM   #7
2286
I bought a set last year for my 135is. Was going to replace the factory tips off the PE but never got around to it. But I do recall the tips being really good quality.
On my Z, I have a pair of 3" dual slant cut tips on my custom exhaust. Picked them up on eBay but they really follow the lines of the bumper nicely:
      07-29-2015, 12:29 AM   #8
StickMon
StickMon's Avatar
Drives: 2006 MR
How the heck do they make those double wall tips?
My Diablos have them, and the taper on the I.D. is so clean it looks like they were machined from a solid billet of stainless.
      07-29-2015, 07:55 AM   #9
DEG
DEG's Avatar
68
Drives: 2007 Z4 MR
I have no idea but IMHO they really dress up the exhaust and fill in the rear opening nicely.
      07-29-2015, 05:33 PM   #10
R0ME0
"The Midas Touch"
R0ME0's Avatar
520
Drives: F87 LBB ///M2
2017 M2  [10.00]
2008 Z4M - SOLD  [0.00]
I wonder if 3.5" tips will fit. The 3" Diablo tips seem a bit small its been something I've been wanting to swap out for a while now on my Diablo setup and also to single wall
      07-29-2015, 06:16 PM   #11
UntzUntzUntz
Drives: 21 M2 Comp
3.5" is huge. It will barely fit but it would also be touching the bumper. By the time you get home from the muffler shop your rear bumper would look something like this:
Here's 83mm tips on the Eisenmann exhuast:
83mm = 3.26772"
3.25" is probably ideal. Anything more it'll turn your bumper into s'mores.
