10-03-2013, 12:33 AM | #1 |
Rep 516
Let talk Wiper Blades!
I'm pretty much driving with no blades since the rubber piece tore off the other day. What does everybody recommend? I am open to trying aftermarket, and also okay with OEM.
Are replacement insert still available? Thanks! luckily it doesnt rain in Socal until later in the year!
10-03-2013, 01:27 AM | #2 |
Rep 1,034
For dealing with Seattle weather I've had the best luck with the OEM inserts. I had a pair of Bosch Icons turn into a noisy streaky mess after 2 months and the OEM ones I have now just might be almost a year old.
Too bad the inserts aren't available anymore.
10-03-2013, 07:10 AM | #4 |
Rep 1,546
I got a pair of those Rain X blades and in Germany they're great. Rain/snow/mud/bugs, no streaks
10-03-2013, 09:33 AM | #5 |
Two Wheels or Four?
93
Rep 655
The dealer just changed mine out (extended maintenance), so they must still have the inserts. The invoice doesn't show the full wiper head, just the blades.
Current: '18 AW Performance Edition m240i Gone: '15 Mineral Grey m235i || '07 Silver Grey M Coupe || '11 Space Grey 328i XDrive || '08 SparkG M3 || '01 LSB M3 || '01 TiAg 330ci |
10-03-2013, 09:47 AM | #6 |
Mechanical Engineer
96
Rep 1,025
I find the rainX lattitudes to work the best, but I usually use Bosch icons because the look soooooooo much better. The rainX's are probably 15% better. if you live somewhere with a lot of rain (not seattle, i mean actual rain like upstate NY or Minnesota) you might want to go with the rainXs.
10-03-2013, 01:50 PM | #7 |
Zed Head
314
Rep 233
Drives: 2020 BMW Z4 M40i
I've been driving for 33 years now and have tried almost every blade out there. Some are slightly better than others but none really last more than 6 months before they start streaking or chattering. There is no real advantage to spending $20-30 per side for some brands. Some aftermarket blades don't conform to the bottom right corner (about a 3 inch triangle). My recomendation would be either get the refill from the dealer or buy a cheap aftermarked set like Anco every 6 months and use Rain-X liberally and fill your washers with Rain-X wiper fluid.
10-03-2013, 04:28 PM | #8 |
Rep 1,247
This reminded me of a question I had....
My drivers side blade has a little "spoiler" on it (not sure what up call it) that add's extra downforce in the wind. The passenger side does not. My questions was - is this stock? If so, should I have 2? Just curious........ Matt |
10-03-2013, 07:17 PM | #9 |
Rep 1,663
Stick with OEM, $13 bucks using part number 61611470281, includes both sides. Takes five minutes and they work great.
There's just one, you're good.
10-03-2013, 07:41 PM | #10 |
Rep 106
It's funny you guys mention OEM wiper inserts. I've been denied from my local BMW dealer (6 months ago) when I attempted to purchase wiper blade inserts. They claimed they're not stocking them anymore, and require purchasing the wiper blade holder as well. According to realoem, there's still a part number for the insert rubber.
I've been using PIAA silicone inserts in my other car. they seem to work well....available on Amazon in different sizes. |
10-04-2013, 12:07 AM | #11 |
Rep 516
Tischer has these for 13 bucks + 12 dollar shipping! anywhere cheaper?
10-04-2013, 12:55 PM | #13 | |
Rep 1,663
You should check your dealer as well. On small cheap items they are sometimes competitive in price.
10-05-2013, 11:53 AM | #14 |
Rep 104
Use OEM blades and if you clean them on regular basis like when you gas up they last much longer. Wipe the rubber part of blade get the dirt and crud off they last longer.
