      08-11-2013, 10:19 PM   #1
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Wheel Bearings (how hard to replace?)
Hi, considering on changing all 4 wheel bearings in my mcoupe. How hard is this? Can I do this without specialised equipment?
Any one point me to a DIY?
I've done it before on a Nissan patrol, but never on a bimmer...
Oh and can someone link me to the best value oem set of wheel bearings. Or is there a much more liked aftermarket set that I should be looking at?
Cheers
Powered by
      08-12-2013, 08:10 AM   #2
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
Subscribed to find out the answer.
Wheel bearings are wheel bearings, I've never had any negative consequences from finding the cheapest supplier.
      08-12-2013, 11:26 AM   #3
rsutoratosu
Drives: Z4 3.0i
does't look too hard right ? I thought they had to be pressed into the hub ?
http://www.realoem.com/bmw/showparts...40&hg=33&fg=40
-Roranji
      08-12-2013, 12:20 PM   #4
Jroc
Drives: Mcoupe
Some cars are hard, some are easy, sometimes the fronts are easy and the rears are hard. Havent seen anyone talk about the job on the z4m.
The rears of my E39M were brutal, and the fronts took 30min.
07 TiAG Coupe
@Jroc561
      08-12-2013, 12:46 PM   #5
jdoublehcubed
Mechanical Engineer
My experience is that getting the actual bearing in and out is easy, the question is how much work it takes to get to that point.
I've only done wheel bearings on FWD cars, usually the rears are <30 min and the fronts are a huge PITA that involves completely removing the knuckle from the car.
      08-12-2013, 01:27 PM   #6
CJW2OO4
CJW2OO4's Avatar
I have recently done all four. The rears are a bitch. You need a large bearing puller seperator. Make sure you have the right size socket. My girlfriends Dad helped me do the bearings. You may also want to have a torch to heat up the bearings so that you can remove them. Its a frustrating job. The fronts were easy though.
      08-12-2013, 10:31 PM   #7
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Damm, that sounds hard.. And I don't have a bearing puller... How long did it take to do the rears?
Powered by
      08-13-2013, 07:56 AM   #8
CJW2OO4
CJW2OO4's Avatar
You could do all four in about 6-8 hours depending how quick you work and how baked on the parts are. For me it took a couple of days because I didnt have the necessary tools and was illprepared and spent time driving around and buying everything. There are a number of videos of the job being done with a few of the best videos being the ones involving E46s.
      08-13-2013, 08:17 AM   #9
Geauxkart
Geauxkart's Avatar
13
Drives: 2007 Z4 M Coupe Sepang
Do you have a press available? I have watched numerous people replace wheel bearings with improper methods. When this happens, they fail quite quickly. If you don't have the tools or knowledge on proper bearing install, take it to someone that does. I work for the largest bearing distributor in the US if it adds any credibility...
      08-13-2013, 09:08 AM   #10
jdoublehcubed
Mechanical Engineer
I feel your pain there. Feels like every project I did on my Audi TT was an exercise in finding new and exotic tools to buy.
      09-23-2013, 09:12 PM   #11
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Cjw2004, do you think you could do a DIY write up? Or just put some general tips and do nots together? The day is looming closer and closer that I have to do mine. I just got quoted 1500us from my indi, and well that's steep.
      09-23-2013, 09:44 PM   #12
seank
enthusiast
seank's Avatar
48
Whs. Fronts not too bad. Rears will make you wish you paid someone else.
      09-24-2013, 08:48 AM   #13
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
Here are some pics from when I had to replace a front hub due to trashing some hub threads.
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500
      09-24-2013, 10:08 AM   #14
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Thanks Bignose, the front looks do-able, but how would one get that bearing case outa the hub? Is that a big drama or would it slide out piss easy like?
(I bet the answer is no no NO)???
Powered by
      09-24-2013, 11:03 AM   #15
bignosejim
bignosejim's Avatar
The inner bearing race came out pretty easy with the puller once everything is lined up straight. Mine came out with almost no effort at all. I did have to put a small socket extension in the middle of the hub to give the puller something to pull against.
I just did that one on the front. I don't have any experience with the rear bearings.
      09-25-2013, 02:07 AM   #16
BMW Maniac
Drives: Former Z4M coupe owner
Fronts are actually pretty simple....rears are and have always been a bitch on BMWs
1999 /// M3 Convertible Techno Violet
      09-26-2013, 01:12 AM   #17
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Ok, I just got a revised quote for just doing the rears. It's 350us dollars.. Including parts and labour., Recon I may get them to do the rears for that.. Whada u guys think? And then tackle the fronts myself if required...
Just to recap, they wanted 1500us to do all 4, but only 350us to do the rears.., recon they have that the wrong way round???
Powered by
      09-26-2013, 01:43 AM   #18
BMW Maniac
$350 for parts and labor for both rears is what I would consider not only fair, but, having done it on other cars, well worth it! If you want to tackle it, fine, but make sure you have the right tools!
Fronts are easiest by far. If you can knock out the rears, then you'll have no problem doing the fronts.
Rear wheel bearings are even worse on older cars too....may not be so bad on the Z4 though since I don't think rust has set in yet. I also don't think you need to worry about your wheel bearings unless you are above 120k miles
      09-26-2013, 02:14 AM   #19
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Yep, coming up to around 190k kilometres on my M. I may just swap out the rear wheels to confirm the noise isn't coming from them, but yeah I'd recon it's the rear (??) wheel bearings...
Powered by
      09-26-2013, 07:40 AM   #20
CJW2OO4
CJW2OO4's Avatar
350 for parts and labor is a steal for the rear. Go ahead and do it.
      09-26-2013, 10:57 AM   #21
RADRACR
RADRACR's Avatar
Is it safe to say that rear bearings wear out much slower than fronts due to the stress of turning the car or am I off base?
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts
'09 X5 35dSpace Grey / Saddle Brown
20" Forgestar F14 / SCR Delete
      10-01-2013, 12:11 AM   #22
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Not sure, but I'd like to know as wel if the fronts or rears should wear out quicker? Anyone with any insight??
