      01-29-2014, 01:52 PM   #1
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
18" vs 19" wheels for autocross
Is there a benefit or drawback to either size? I have been focused on putting together an 18" set for autocross but have noticed a few wheels that I would like better in 19". With the same model tires/circumference, is there one that's better?
      01-29-2014, 04:25 PM   #2
Incompatible
Drives: 07 AW Z4C 3.0Si
The lighter the better. A lightweight 18" will be lighter than a lightweight 19" assuming similar price range. Some have even gone to 17" wheels if they will fit over the brake calipers. Another benefit is (generally) you have a larger selection of tires as the wheel diameter decreases and decreased tire cost.
      01-30-2014, 03:45 PM   #3
a_riddler
Bimmer Noob
a_riddler's Avatar
Drives: 08 Z4MC;08 MBZ E350 4Matic
Yeah, neither. Get a 17" wheel. AutoX isn't about looks, so a 19" nice looking rim is the wrong choice. 17" wheel = lighter weight and cheaper tires!
http://www.apexraceparts.com/ARC-8-1...eel_p_150.html square setup with 265's! oh yeah!
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing,
AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges
      01-30-2014, 09:28 PM   #4
seank
enthusiast
seank's Avatar
48
And you can change tire sizes (sidewall), which means you won't need to put a 4.10 in the diff. Smaller 17" tire will have a lower center of gravity also.
      01-30-2014, 09:37 PM   #5
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Plus, high pressure will compensate for sidewall rollover. I think
      01-31-2014, 09:10 AM   #6
DRedman45
DRedman45's Avatar
35
Drives: E86 //M coupe
But the higher pressure is going to reduce grip...a 40 series or even 35 if you go with wide tires would be best on 17's imo
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread
      02-02-2014, 11:48 PM   #7
mtrhed
mtrhed's Avatar
13
Drives: 06 AW Z4MR/w211 e63 AMG/325XiT
06 Alpinweiss Z4M R
Anthracite Apex EC-7 9F/9.5R, 245/275 Super Sport's, 17" Kosei K1 255/40r17 Direzza II, SS Lines, Pagid RS29, Ate SuperBlue, VT Comp. MM's, RE trans. mounts, AST 4150, Swift springs, Vorschlag camber plates, RE RSM, H&R swaybars, spherical rtabs, SuperFlex poly fcabs, StrongStrut Braces, Euro Headers, Stromung exhaust, ESS Tune, Eventuri intake
      02-03-2014, 07:07 AM   #8
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
17s, if you can get them.
You need sidewall rollover to get maximum grip. Pressure will vary in order to get precise rollover at the arrows marked on the tire
