07-23-2014, 08:24 PM | #1 |
Rep 9
Headlight ballast access/removal
I bought a 2003 E85 (97k miles) with the right headlight out. I replaced the bulb then the igniter but headlight is still out. I believe that the last one to replace now is the ballast. if that does not work, any ideas. If it is the ballast, how can I access and remove it without removing the front bumper. I know I cannot take it out using the 2 access points from the wheel well.
Your assistance would be greatly appreciated. Technobuff |
07-23-2014, 09:12 PM | #2 |
Rep 2,547
I would be swapping parts from the working headlight to the non-working. It could be the wiring or even the LCM.
If you can't get the ballast off through the wheel well access panel, then the bumper probably needs to come off. |
07-23-2014, 11:42 PM | #3 | |
704
Rep 7,850
DIY for bumper removal here, pretty easy to do. |
