Go Back   ZPOST > BMW Z4 Roadster and Coupe > Regional Forums > Canada
      07-31-2015, 08:01 AM   #1
Mirko
Mirko's Avatar
Drives: E86 Z4M, E90 328i, E84 X1
Headers, Stock Secondary Cats & Drive Clean
Hi All,
Just wanted to post some info for those wondering if your car will pass Drive Clean or not when you get headers and modify the secondary cats to accept the O2s.
The answer is, yes you will. I passed 2 weeks ago, no issues.
I do have EPIC software but I had it installed prior to headers and even after retunes never had them turn down or turn off the secondary O2 readings.
I've run well over 6K km without a light and hopefully will continue to do so
For anyone concerned about drive clean as I was, seems to be no issue.
Happy modding
08 M Coupe • Ceramic Black Fabspeed Headers • MCS 1WNR • Poly FCAB • Stoptech BBK • Vibra-Tech • Epic Tune • Apex EC7 • RPI Scoop • Eventuri • Stromung • Rogue X Pipe • Varis Diffuser • CF E92 GTS Wing • CF Roof
      02-28-2016, 07:31 PM   #2
NeoGeo
Drives: E92 M3
Thanks for the info Mirko. I was part of the DFK fiasco. I still haven't installed the secondary cats, but I am already running software from AA.
Now that spring is approaching I've been considering what to do.
I'm a bit fed up of the whole modding thing, but if this works out like yours did, I'll keep the car. If not I'll return it back to stock and flog it for a p-car.
      02-28-2016, 07:35 PM   #3
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
I had a readiness fail in November; Cleared the codes before the test. Stupid move. I need to drive some cycles in a few weeks and go back for the test. We'll check the readiness before the test.
2006 Z4MC - #LL93158
      03-02-2016, 03:33 PM   #4
kav
Drives: Z4M
I must just be unlucky.
I have the ESS tune, euro headers, ss power loop exhaust and X pipe with relocated o2 sensors.
I failed 2 years ago and again this week.
I've restore US NA OEM ESS tune and will try again.
Where did you guys go for your testing?
      03-02-2016, 06:34 PM   #5
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
In stock form I went to EA in Vaughan under the new testing. This last one I went to CT locally. It must be the tune shutting off your CEL. I would go to EA myself if in your shoes. They deal with our situations regularly.
      03-02-2016, 07:19 PM   #6
Mirko
Mirko's Avatar
I went to a Jiffy Lube near my work.
      03-02-2016, 07:22 PM   #7
Mirko
Mirko's Avatar
It should really work so long as you relocate the O2 sensors. Just make sure that the AA software doesn't turn off the readiness for your secondaries, otherwise you won't pass. Wishing you all the best!!
      03-03-2016, 05:11 PM   #8
kav
Drives: Z4M
Passed after restoring tune to NA US OEM ESS file.
Now back to euro tune.😄
      03-04-2016, 11:47 AM   #9
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
      05-01-2016, 01:26 PM   #10
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Ian and I both passed last week!
      05-01-2016, 02:04 PM   #11
kav
Drives: Z4M
What tune are you guys using?
      05-01-2016, 04:13 PM   #12
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I have a base ESS tune, Caddy has no tune.
      05-01-2016, 05:07 PM   #13
kav
Drives: Z4M
Ian
Is your ESS tune the Euro tune?
Or is it he NA tune?
So you have the self flash? I'm curious to hear your thoughts if you have tried them both.
      05-02-2016, 06:53 AM   #14
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Ian
Mine was done before self flash was available.
It's the base NA, non header tune.
I need to update it.
      05-02-2016, 07:13 PM   #15
garz747
Drives: 07 Z4MC 01 330i 18 X3 M40i
My M is dead stock- as in unmolested!! Hope i dont get left too far behind! Passed e test when i bought it end of last summer with no issues of course.
      07-22-2017, 11:54 AM   #16
Mirko
Mirko's Avatar
Just an update.
Another 2 years have gone by and I did the drive clean yesterday, passed with everything set as ready. No modifications or changes have been done to the car with respect to emissions.
      07-24-2017, 07:55 AM   #17
GTA Z4MC
Drives: Z4MC
Hi Mirko
Amazing.
What is the location you are going to?
      07-24-2017, 02:10 PM   #18
Mirko
Mirko's Avatar
Originally Posted by GTA Z4MC View Post
Hi Mirko
Amazing.
Do you mean location of where I got the emissions test done? It's just a quick oil change place called Pennzoil 10 Minute Oil Change Center.
      07-24-2017, 05:33 PM   #19
GTA Z4MC
Drives: Z4MC
Yes
E Test.
Thx Got it
      07-27-2017, 03:21 PM   #20
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
I am unfortunately still not passing. Have had expired sticker since May.
EPIC sent multiple tune revisions, I relocated my O2s behind secondary cats as others have done and the car still never becomes ready for Oxygen sensor or Catalyst monitoring. It's been driven over 2000km in total trying different things, reading multiple posts on achieving readiness, from letting the car sit 8+ hours, idling on startup and idling before shutting off to keeping it under 3000RPM for entire trips to beating on it, maintaining speeds of ~50, maintaining speeds of ~100 with/without throttle input changes, I can keep going. In short, it never becomes ready and it never has a single fault.
I'm almost to the point where I am willing to take the temp pass and have another 2 years to figure this out.
E86 ///M Coupe - Imola Red/Imola Red
E60 ///M5 - (6 Speed) Silverstone Metallic/Black
F06 640iX - Tanzanite Blue/Amaro Brown
K66 ///M1000RR - Competition
      07-27-2017, 05:20 PM   #21
Steeler
Steeler's Avatar
2429
Same boat here
Maybe in 2 years this asinine emissions program will be scrapped
      07-27-2017, 06:41 PM   #22
Mirko
Mirko's Avatar
That's crazy why it isn't working for you. Maybe go back to stock tune and check if your 02 sensors are actually bad, might need to change them. Are the correct 02 sensor connected to the correct bank? Ian, Dave and I all pass with no issues so it's weird.
