      10-12-2013, 06:50 PM   #23
zubydafa
tosser
Isle of Man
31
Drives: '07 Z4MC
Originally Posted by 604skyline View Post
Tommy,
you know arqray makes an x pipe right?
http://www.fame-web.com/shopping/z4/mu/MUAQRTSZ4.html
likely fantastic quality. i had arqray cans on my mcoupe for a while. such a good sound.
'07 MCoupe
lots of mods
      10-12-2013, 07:49 PM   #24
604skyline
Drives: 2020 M2 CS
it appears they may come in stainless or titanium with the titanium one being a pretty penny...
      10-20-2013, 09:14 AM   #25
just2talented
just2talented's Avatar
Drives: Alpine ///M roadster
If your not looking for show car quality underneath your car then you might want to go the route i did and just cut out your resonator. Thats all the x- pipes are anyway, stock pipes with those cut away, had mine done at a local indy shop. $100. Small power gain, fantastic sound. Dont waste your money.
      10-20-2013, 11:15 AM   #26
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
increased rasp?
      10-20-2013, 12:47 PM   #27
MPowerZ32
MPowerZ32's Avatar
66
Drives: Man
Originally Posted by mousitch View Post
Wait on DKF. Super sprint needs adapters and my rogue didn't fit properly. I bought both. Rouge installation requires bending of rear support to avoid rubbing on passenger side pipe which I fully do not recommend.
hmm... I have Rogue X-pipe and didn't have installation issue.
      10-20-2013, 01:43 PM   #28
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
They seem to be hit & miss to varying degree.
I've done 2 one was not bad the other needed the pan adjustment as mentioned above.
      10-21-2013, 03:14 PM   #29
MPowerZ32
MPowerZ32's Avatar
66
Drives: Man
Makes sense. I think I might have got lucky with mine. Maybe if the exhaust cans are adjusted to hang a bit higher and closer to the bumper, it could help clear the rear support.
      11-04-2013, 03:04 PM   #30
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
did you happen to cut the resonator open???
...curious what the path(s) are through that thing.
      11-24-2013, 09:35 PM   #31
habitat412
Drives: 2008 Z4 M Coupe
I just had a custom complete exhaust system made for my car from my buddy who owns a performance shop and does fabrication. 3" dual piping all the way back up to the muffler area and then had the muffler section made from 4" titanium with dual 4" titanium tips. V band clamps to hold everything and no cats and no resonators at all. Saying it is loud is an understatement. I need to get a video posted up here for you guys to hear it! It will make your ears hurt but sounds like an ALMS car when I floor it!
      11-24-2013, 09:36 PM   #32
habitat412
Oh yeah forgot to mention the rest of the system is made from aluminum so it's super light and sounds different then using stainless steel.
      11-25-2013, 03:13 AM   #33
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Post up some clips! Sounds, no pun intended, interesting!
      11-25-2013, 09:17 PM   #34
BlackMoupe
Mouper
BlackMoupe's Avatar
Drives: _____
I also had a BMS X-Pipe and mufflers. X-Pipe had no flat spots and kicked up the rasp a bit. Butt dyne felt a bit stronger.
Cell phone sound clip here.
      01-02-2014, 10:57 AM   #35
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
I'm extremely curious to see if anyone has done a video of a secondary cat delete and the RE X Pipe with stock mufflers. I'm thinking this is going to be the perfect combo for daily.
      01-02-2014, 11:07 AM   #36
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
hopefully there will be some from the DKF section1 GB that will make some recordings.
      01-02-2014, 11:45 PM   #37
StickMon
StickMon's Avatar
Drives: 2006 MR
I have RE cans and I'm seriously thinking about the RE section 1 and X-pipe.
Need to wait until after tax-time in case I get soaked.
      01-03-2014, 08:43 AM   #38
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
Did you do headers/other sections already? Or do you just have the cans?
      01-03-2014, 02:35 PM   #39
StickMon
StickMon's Avatar
Drives: 2006 MR
Just the cans. Gonna stay with stock headers as it's a DD.
      01-03-2014, 08:34 PM   #40
Gallardo Rosso
Drives: 2007 Z4M Coupe
I had my stock x-pipe off and if you look down the pipes you can see the construction. Looks like a standard resonator construction. Perforated pipe sharing one chamber... Can't see it but the chamber is probably packed.
