      02-22-2018, 03:27 PM   #23
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
My window sticker says country of origin engine and transmission: Germany
final assembly point Spartanburg SC, USA
Thanks!
That eliminates a possibility. The diligence over time post crisis mode is still viable. Not provable. But typical in terms of human behavior.
Yeah, as far as I know, all S54 engines were built in Germany and shipped to Spartanburg for assembly. It's interesting that the S54 bearings still were problematic in the Z4M after the issues with the S54 in the M3. Some speculated that a design change in the S54 engine for the Z4M would have constituted an admission of guilt by BMW, so they left the journals the same width as in the M3. Lots of speculation involved in these discussions
Anyway, here is a cool video of the rod bearings being assembled in an S54. Wouldn't it be cool to have that pneumatic dual torque wrench? It's also interesting that unless they didn't show the step, there are no multiple torque tightening procedures during initial assembly. Just crank it down to a specific torque, but they are doing both bolts at the same time. That's probably the difference.
3 minute mark is where the rod bearings are tightened. Timing set at around 5:20. Valve shims at 6:40. Note no assembly lube is used on the floor...just oil.
Lots of good material in the video:
https://www.youtube.com/watch?time_c...&v=ZjFVV5HXU0Q
Salty
      02-22-2018, 03:33 PM   #24
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6185
Doesn’t S65 have the same issue? There are no “safe” S54’s imo
      02-22-2018, 07:19 PM   #25
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Yes, the S65 (and S85 from which the S65 is derived if I recall) has this issue. No lead in those S65 bearings either, so there's no warning flags. (Note, I'm not sure if the no lead is all or just replacement bearings.)
      02-22-2018, 07:51 PM   #26
rockstar93
rockstar93's Avatar
Drives: E86 Z4MC; E92 M3
IIRC the bearing composition was changed on E9X M3's in MY11. Prior to 2011 bearing wear is more easily detectable because of the lead. No evidence that the bearing composition quickened or slowed the wear.
E85 Z4M Roadster Imola Red/Black GONE
E90 M3 Sedan 6MT Jerez Black/Fox Red GONE
E86 Z4M Coupe Interlagos Blue/Black
E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread
      02-22-2018, 09:35 PM   #27
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6185
Should figure out what Porsche does with the GT3. I think I remember hearing their engineer say that they run a ton of oil pressure in the new 4.0
Edit — just watched that video again, it’s actually the opposite. They run low oil pressure, have bigger main bearings, and sounds like they have oil coming out of holes in the con rod journals? Can’t remember if ours does that. Watch vid below @ 11:40
Double edit — yeah ours does too. Maybe GT3 eats bearings too lol
      02-25-2018, 11:45 AM   #28
Andyh1
Andyh1's Avatar
115
Drives: 2006 Z4M black saphire / imola
Great thread... I will be adding to this conversation soon, next weekend I will be doing my oil change. I have been using Liqui Molly 10w60 with Liqui Molly Nos2. We will see what comes back from the lab.. Sitting at 29K
      02-25-2018, 12:54 PM   #29
GuidoK
#buildnotbought
GuidoK's Avatar
10965
Drives: Z4 3.0i ESS TS2+
Sounds to me that he describes that the rodbearings are fed by oil which is pumped through drilled passages in the crank.... Like every automotive engine has had for the last 50 years?
      02-26-2018, 07:13 AM   #30
SaltyNC
SaltyNC's Avatar
370
I think the S65 takes the prize for the worst rod bearing problems. Some were toast after crazy short mileage.
Salty
      02-26-2018, 09:12 AM   #31
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
Mine is going in to my indy for bearings tomorrow at 68.5K miles. Just not willing to roll the dice anymore every time I drive it.
For sh#ts and grins I called the dealer to get a quote from them. The service advisor called me back and told me $9300. I said "thank you for your time". Even if they assumed a crank replacement as part of the service I don't know if it would have come to that much $$. I didn't want to spend any add'l time on the phone with them investigating what work the quote covered.
      02-26-2018, 11:29 AM   #32
racerbruce
racerbruce's Avatar
3855
Drives: 21 X3 & 13 335is E93
What is costs for rod bearing replacement??
If any are comfortable, could you provide us with the appx cost if completed by an indy??
Racerbruce
      02-26-2018, 02:02 PM   #33
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
For just my rod bearing service last week at TYSpeed in NJ, it was 10 hours of labor for a total of $1,050. ECS tuning WPC rod bearing kit was an additional $675. Hope this helps and I highly recommend this shop if anyone is in the area!
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red |
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage
Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo
      02-26-2018, 07:36 PM   #34
StickMon
StickMon's Avatar
Drives: 2006 MR
Yea, I think in general you're looking at $1600-$1800 from an indy with parts and labor.
Finnegan707.00
      02-27-2018, 09:54 AM   #35
racerbruce
racerbruce's Avatar
3855
Thank you to Azeka1 and StickMon for the cost info.
Racerbruce
      03-01-2018, 02:38 AM   #36
Finnegan
Finnegan's Avatar
That's in the same price range as here in California. Parts price went way up recently. Stickmon gives a good range.
That dealer must have been replacing the flux capacitor and blinker fluid in addition to the bearings.
      03-05-2018, 09:50 AM   #37
elerner61
elerner61's Avatar
157
My indy must be better than yours, he charged $2,300. Only guy near me I trust though. 68K miles and glad to have it done in time for top-down season to start (any day now). My last Blackstone reported 34ppm Lead but zero Copper (I got lazy and missed two oil changes/two years of having it analyzed though). From my pics I would have thought I'd have non-zero Copper.
      03-05-2018, 09:58 AM   #38
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
That is the best looking bearings put up on this thread thus far
      03-05-2018, 10:26 AM   #39
elerner61
elerner61's Avatar
157
Still, they're not looking good. Here's my use info:
- Live in NorthEast (New York City suburb)
- Car not tracked or auto-crossed, enthusiast driven
- Drive the car all year round (down to 20 deg. F)
- Annual oil changes at 7.5K miles or less (always in Fall, before cold weather)
- Castrol TWS
- No cold engine drives shorter than 20 minutes
- Engine run period of 2 mins before driving on cold start
- No engine revs over 3K until engine is at 165 deg. F
- No "fun" driving until engine is fully warmed up.
It is what it is. So happy to be driving it again. Now I just need to avoid the melting snow/salted road water runoff in March. Would be nice if we had a warm, dry March like we did last year. After this Wednesday's snow storm that is.
      03-05-2018, 09:47 PM   #40
SaltyNC
SaltyNC's Avatar
370
It is weird how in all these oil analyses, we see bearings showing a lot of copper, and it doesn't show up in their report. Could it be the copper doesn't wear from the bearing the same way the lead wears away? It seems like there would at least be a little rise in copper, but it doesn't happen.
Agree, your bearings look good in comparison to others. I'll be doing mine very soon. I've been honing my mechanical abilities on my son's 330Ci.
Salty
      03-06-2018, 12:37 AM   #41
Finnegan
Finnegan's Avatar
Salty
Good question. Wondering the same thing too.
      03-06-2018, 09:43 AM   #42
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
This is the quote I got from Blackstone when I asked the same question about copper:
"We would expect copper to start rising too once the lead layer has worn away. The pictures of the bearings you sent clearly have reached the copper layer in some of them, but maybe your engine was making metal that's bigger than our machines can read (we look at the microscopic metal). Hopefully, lead will stay low going forward now that you've replaced the rod bearings."
What I got from their response is that copper might be wearing away in larger chunks and therefore gets trapped in the oil filter and thus doesn't show up in their machine that only looks at things at a microscopic level? Does this make sense?
      03-06-2018, 02:29 PM   #43
KevinM
KevinM's Avatar
2936
Drives: 2002 M5;2007 M Coupe;2020 M2C
2020 M2 Competition  [10.00]
2007 E86 M coupe  [8.38]
2002 E39 M5  [9.00]
Wow.
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel
2007 E86 Z4M Coupe Silver Gray/Black
2021 Kia Telluride (hauler)
      03-06-2018, 03:28 PM   #44
GuidoK
#buildnotbought
GuidoK's Avatar
10965
Originally Posted by KevinM View Post
Wow.
Especially if you think about that changing rodbearings is about 1 day of work tops for a trained mechanic. Add in about $900 on parts (1 half of a bearing is $37,-, which is pretty excessive), but even then they thus charge $1000,-/hour....
For $9300 you can almost expect a new engine....
