12-04-2011, 08:16 PM | #1 |
Rep 615
Valve adjustment affect mileage??
I got my Inspection I a couple of weeks ago and 15 of the 24 valves required different shims. While I take comfort knowing that the dealership appears to have been thorough in their work, I can't help noticing that my mileage since then seems to have gone down by 10%-15%. It's possible that it could be partially due to the cold weather which causes cars to run a little richer until they warm up. But could the changes made from the valve adjustment have anything to do with it? It sounds and runs great but the mileage drop is hard not to notice. Anyone have a similar experience? Thanks.
12-04-2011, 08:58 PM | #2 |
Bad Lieutenant
232
Rep 3,517
She shims are designed to wear (more than the valve stretching or seat recession, causing tight valves), so most likely the valves were on the loose side and a larger shim was introduced to bring the lash into spec, allowing more fuel/air mixture, as well as increase exhaust breathing. My mileage has always gone down after an adjustment, but after a few days, it levels again. Did you get the spec sheet as to the before and after tolerances?
12-04-2011, 09:57 PM | #3 |
Rep 615
Yes. But the way the tech filled it out, he never put the clearance measures on the sheet. He starts out simply citing whether the valve was within spec or outside spec. Then, if it was outside spec, he included the size of the existing shim, the one that he substituted for it and that the final gap was within spec. In all cases, the shim used was one size larger than the one it replaced.
12-05-2011, 08:40 AM | #4 | |
Bad Lieutenant
232
Rep 3,517
12-05-2011, 08:51 AM | #5 |
Save the Manuals
1714
Rep 2,937
why?
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
12-05-2011, 08:54 AM | #6 |
Bad Lieutenant
232
Rep 3,517
Cooler engine, safer for the valves, especially on the exhaust side.
