03-12-2015, 07:39 PM | #1 |
Rep 115
Removing Belt Cover in Engine bay
I want to remove the plastic cover shown in the image below to check the belts and cooling system seals. This really shouldn't be difficult but BMW seems to think otherwise. It looks like I need two different types of screw drivers to remove all the bolts (Torx, and something else for the small screws). Any advice for me on the best way to get this off?
Can I leave it off once I remove it, or does it actually do something useful? |
03-12-2015, 07:45 PM | #2 |
Rep 2,702
Belt access does not increase with that removed, there is still the radiator support underneath.
The cover itself serves as a cover to hide the ugly sheet metal but also to stabilize the radiator. The 2 torx looking fasteners on the raised portions insert into 2 recesses in the top of the rad.
03-12-2015, 07:54 PM | #3 |
Rep 115
A friend of mine who also owns a BMW says that there is a little plastic piece on the cooling system that is prone to breaking or wearing out, and that it can cause a lot of damage if it happens. According to him, the only way to check this is to remove this plastic cover. Is this true, or does he have no idea what he's talking about?
03-12-2015, 08:00 PM | #4 |
Rep 2,702
The expansion tank is under there on the drivers side.
If you do not have any loss of fluid why mess with it? If you do want to remove the cover to investigate what is under there, the plastic torx fasteners are a push style fastener. You thread them out to disassemble and push them into to reassemble. You will likely have to exert some upward pressure under the head of fastener as you thread it out.
03-14-2015, 06:46 PM | #5 | |
Rep 106
03-15-2015, 05:45 AM | #6 |
Rep 18,691
I'll add that the expanding rivets are usually one-time-use fasteners and you'll break or mung-up most of them upon removal, so it's best to buy replacement fasteners before you remove the panel. They are plastic and have a Phillips screw head. You unscrew them a bit, then pull them out with pliers or a panel removal tool. There are eight (8) total and are P/N 51168197908. I paid 34 cents each a month or two ago when I ordered them on line. I bought 12 just incase a few broke going back in...
03-16-2015, 05:18 AM | #8 |
Rep 18,691
The one I use is a snap-on that a mechanic left in the engine bay of one of my cars a long time ago. But it is the tool used to remove those big-head plastic buttons that hold interior panels on, like the trunk panels. It looks like a small pry bar with a screw driver handle and has a wide flat tip with a u-shaped cut in it. Any auto parts store will have one.
03-16-2015, 10:31 PM | #9 |
Rep 115
So is it true that there is some $2 plastic piece for the radiator under there that can save you tons of money if you catch it before it breaks? Can anyone tell me more about this?
03-17-2015, 09:06 PM | #10 |
Rep 911
Drives: 2020 X3 M40i
Removal of panel is easy.. I just did. Phillip screw heads aren't really screws, they are the inserts for plastic tabs, once retracted 3/4 inch; tab pulls out. The catch is, they don't always come out easy - acting stripped. After that, two torx bolts on either side. Panel lifts out - rubber inserts (with large torx heads, will pull out). M3griff is correct, though, not much access to belts, unless you remove radiators.
