09-21-2018, 08:54 AM | #2 |
1821
Rep 5,337
No.
09-21-2018, 09:26 AM | #3 |
Rep 12,565
Fronts maybe with ton of camber
Rears very doubtful unless again ton of camber plus stretched tires |
AK72286.00 |
09-21-2018, 09:51 AM | #4 |
1821
Rep 5,337
I guess it depends on one's definition of "fit," because it's going to take, in addition to camber, a narrow tire to "stretch" onto the 9.5" wide wheels to avoid rubbing the fender.
If OP's definition of "fit" is just being able to stuff the wheels under the arches, actual function of the wheels be damned, YES both the front and rears can "fit." With that width and offset, on a 3.0Si? I wouldn't even bother trying. And we haven't even factored in suspension and lowering. On stock camber and suspension, the front is going to stick past the fender by more than 1/2", and the rears will likely be more than 1". But the car will roll, as long as it's only going in a straight line (and not have to brake or accelerate hard).
AK72286.00 |
09-22-2018, 07:42 AM | #6 | |
Rep 399
Maybe you can suggest me size that will fit my car without any Issues? |
09-22-2018, 09:21 AM | #7 | |
1821
Rep 5,337
18” x 8” et47 front 18” x 8.5” et50 rear.
bgeorge004920.50 |
09-22-2018, 11:48 AM | #8 | ||
Rep 12,565
But I would skip VMR, too heavy for my tastes |
09-22-2018, 03:19 PM | #9 |
Rep 2,704
+1 on the Apex Wheels
I am running these specs 18x8.5" ET35 225/45 18x9" ET30 255/40 lowered with very little camber My fronts could take a 6mm spacer.
AK72286.00 |
09-22-2018, 05:06 PM | #10 |
Rep 758
For reference I'm currently running 18x8.5 +40 on all 4 corners with Hankook RS4 275/35 in the rear and 265/35 in the front.
Suspension is OEM M Sport springs with Koni Sport struts/shocks. Rear camber is at max attainable with factory adjustment (-2.5), same for the front at -1.3. I get a slight rub on the inner edge of the front fender liner at the top of the arch under really hard cornering, no issues in the rear.
Top Down 365
AK72286.00 |
09-23-2018, 06:57 AM | #11 |
Rep 399
that is factory setup I have now, lol Last edited by AK72; 09-23-2018 at 07:33 AM.. |
09-23-2018, 06:59 AM | #12 | |
Rep 399
09-23-2018, 09:12 AM | #13 |
Rep 12,565
Don’t recall but considering they’re 19’s most likely.
09-24-2018, 09:36 AM | #14 |
1821
Rep 5,337
You wanted sizes that will fit for sure with no issues, I complied.
You can infer from the factory size and offset by using an offset calculator based on inner and outer clearance as measured from your factory set-up. That’s the most logical way to figure out if a set of wheels will fit or not IMO.
bgeorge004920.50 |
09-26-2018, 09:26 PM | #15 | |
Rep 399
09-28-2018, 11:56 AM | #16 |
Rep 399
APEX suggested to me to go with this setup, what do you guys think?
Front: 19x8.5" ET35 with 235/35-19 tires Rear: 19x9.5" ET33 with 255/35-19 tires |
09-28-2018, 01:04 PM | #17 |
Rep 2,704
Yup
I had those widths and offsets in 18" with no issues. Not sure on the rolling diameter of those tire sizes though
AK72286.00 |
09-28-2018, 08:45 PM | #18 | |
Rep 758
With the 235/255 tires, it's really just a cosmetic change. If the OP is good with that, no worries, but if there's an expected change in handling, it's not going to be there.
Top Down 365
09-29-2018, 03:12 PM | #19 | |
Rep 52
Front: Rear: |
AK72286.00 |
10-02-2018, 07:17 AM | #20 |
Rep 399
