09-06-2018, 08:14 PM | #1 |
Rep 779
Battery Dead... Autocraft AGM?
My old battery died, the tender wont charge it, says error.
Anyone used the Autocraft Platinum AGM from Advance Auto Parts Before ? So 4-5 years ago, I got my last AGM off autozone for 149, now its 199-225 for the battery. Advanced Auto Part is running a 25% off promotion, check the top of the screen for that 25% off link when you go to the website. So its 199 - 50 + 5 core = 154.99 + tax There's suppose to be a $20 rebate on top of that @ https://shop.advanceautoparts.com/o/rebates in the form of a gift card
-Roranji
09-06-2018, 09:56 PM | #2 |
Rep 2,547
My 7 year old AGM was dead and wouldn't charge on my smart charger due to voltage too low. Hooked up an old school charger for a while then put my smart charger back on and completed the charge. Battery charged up fine and now has been working for several months. YMMV.
No experience w/ autocraft but I'm sure AA uses the lowest bidder for their battery supplier. |
09-06-2018, 10:44 PM | #3 |
636
Rep 3,124
There's a battery options thread:
https://www.zpost.com/forums/showthread.php?t=745266 From the small bit of research I've done, most of the major brands buy their AGMs from the same manufacturers. Long ago I posted pics from the websites of 3 major auto parts retailers, and from the fine details of the battery cases, you could tell they were all the same one, just with different labels. Bottom line, the Autocraft is probably a fine battery, and likely will be from the same manufacturer as a comparable one from AutoZone, O'Reilly, Pep Boys, etc.
Finnegan707.00 |
09-07-2018, 08:40 AM | #4 |
Rep 1,795
Drives: E86 3.0si
I've only had my Advanced Auto's AGM battery in the vehicle for 10 months now, but I can tell you the appearance and the fit are identical to the original...and it performs as expected.
09-07-2018, 01:50 PM | #5 | |
Rep 779
my old school charger doesn't do AGM, can I still try that ?
-Roranji
09-07-2018, 02:41 PM | #6 |
Rep 1,991
In my experience AGM or LA give the same results. I started with the OEM AGM - 5yrs it was dead. Second time a LA was used for lower cost and it lasted 5yrs. Replaced it with another LA a couple of years ago. That being said the deal you posted would probably make me go AGM if it was available. I paid about that much for my last LA battery.
09-07-2018, 03:27 PM | #8 | |
Rep 2,866
In my experience, AGM usually only cost about $10 more than their LA counterpart. I like the extra RC that AGM provides and don't have to worry about potential leaks
09-07-2018, 06:48 PM | #9 |
Rep 2,547
rsutoratosu114.00 |
09-09-2018, 08:14 AM | #11 |
Rep 12,565
I only use Autocraft as replacements because of the AA discounts. Never had issue with any of them on my past 3 BMW’s.
09-22-2018, 07:05 AM | #12 |
Rep 18,742
I really have to ask after reading this thread, what is the advantage of an AGM? I mean if you have to keep it on a charger and they die after 7 years, I see no difference than a wet-cell type.
09-22-2018, 10:16 AM | #13 |
Rep 2,866
If you're going to keep it on a charger weekly and don't live in an extremely cold climate, then there's no advantage of using an AGM. You can just go longer in between charges if you got an AGM since it has a low self-discharge rate. AGM has very low internal resistance, is capable to deliver high currents on demand and offers a relatively long service life, even when deep cycled. It outperforms flooded batteries in cold climates. But if you're able to get 7 years out of your flooded batteries, then stick with that. In my experience, my flooded batteries usually randomly die unexpectedly after roughly 4 years. So, I just proactively replace them every 4 years. I'm experimenting going a bit longer with my AGMs - I may not replace them until 6 years...will see.
09-22-2018, 10:22 AM | #14 | |
Rep 18,742
09-23-2018, 01:29 AM | #15 |
636
Rep 3,124
The AGMs are the only ones that I've had that haven't ended up looking like this after a couple of years.
And that's with felt doughnuts and silicone grease.
09-23-2018, 06:58 AM | #16 | |
Rep 18,742
I've never seen a battery in a BMW do that.
09-23-2018, 10:11 PM | #17 |
636
Rep 3,124
That's a random pic off Google. Have an AGM in the Z, and it doesn't look like that.
I have had many in my other cars and trucks heavily corrode like the pic. Put an AGM in the Expedition, and a couple years later it's clean and shiny.
