      04-21-2018, 08:45 PM   #1
M54E85
M54E85's Avatar
Drives: E85
left rear wheel off center if anyone knows please help
got 2004 E85 just noticed that my left rear wheel is more closer to the bumper rather than the right side wheel, so the left side looks kinda off center, is there any kind of adjusment can be done or the bushings needs to be changed? funny that a month ago seen similar car and had same problem and it was completely stock, the reason i want to get it fixed as im lowered on h&r springs with "15mm pucks and have fenders rolled and slight pull and wheels are 18x10.5 ET22 with 255 35 18, right side rides fines as it seems to be on center but the left side is kinda off and its actually rubs the bumper corner on a bumps.
if anyone can help please let me know
checked the suspension on real oem suspecting one of the bushings might be worn as its looks not adjustable only the camber with eccentric bolt
      04-21-2018, 09:02 PM   #2
wdb
dances with roads
wdb's Avatar
4718
VIN please.
      04-21-2018, 09:16 PM   #3
M54E85
M54E85's Avatar
Drives: E85
its an US car by the way and here is the vin # 4USBT53594LU06474
      04-23-2018, 06:44 AM   #4
M54E85
M54E85's Avatar
Drives: E85
any input would be greatly apreciated. thanks
      04-23-2018, 09:56 AM   #5
longress
longress's Avatar
Drives: 2007 Z4M Coupe
Measure the wheel base on the left side of the car and compare it to the right from center hub front to center hub of the rear wheel. You might have body damage that wasn’t repaired correctly and the actual problem is the back of the car was not put back together correctly.
      04-23-2018, 10:58 AM   #6
M54E85
M54E85's Avatar
Drives: E85
the car is accident free plus i have seen another z4 but 2003 with same thing so im more than sure its something fixable
      04-23-2018, 11:32 AM   #7
The HACK
The HACK's Avatar
1821
What do you mean by "off center?" You mean the wheel is closer to the front of the wheel well? Or that one wheel is closer to the top of the fender than the other?
      04-23-2018, 03:54 PM   #8
M54E85
M54E85's Avatar
Drives: E85
its more to the right beeing a left rear so its closer to the bumper
      04-23-2018, 05:54 PM   #9
StickMon
StickMon's Avatar
Drives: 2006 MR
I'm with longress on this one.
Far more likely that your wheel well is in the wrong place and not the wheel.
      04-24-2018, 06:27 AM   #10
M54E85
M54E85's Avatar
Drives: E85
impossible due to wheel well is same on both side just wheel placement on the left rear is more shifter to right side
      04-24-2018, 08:01 AM   #11
Steeler
Steeler's Avatar
2428
Pictures?
Someone may be able to help with a visual.
Hard to believe the axles and suspension is not centred in car.
      04-24-2018, 09:31 AM   #12
The HACK
The HACK's Avatar
1821
Originally Posted by dbarton62 View Post
Pictures?
Yeah. Useless to keep guessing IMO. Given the age of the car it’s likely a number of combination of things.
      04-24-2018, 10:03 PM   #13
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
It's hard to tell what the issue is from your description but if you're indicating the top of the tire sticks farther out on one side than on the other, that's camber and that's adjustable. There are some bushings in the rear control arms that can degrade and exaggerate the difference.
If you're indicating the tire/wheel looks closer to the rear or front of the car more so than the other side, the only thing I can think of that would allow that is the rear trailing arm bushing on one side is defective. That's the part that has the most effect on the front to rear position of the rear tires.
Top Down 365
      04-25-2018, 07:10 AM   #14
M54E85
M54E85's Avatar
Drives: E85
here is the pics already spoke to one bmw tech said its one of the bushing worn on that side or alignment needs to be done on all 4 corners since rear suspensions is like on e46 there is 3 bolts that can be adjusted to bring the wheel to the center if all of the bushing are fine, car has 74000 miles
hopefully by the end of this week will be putting on the hoist to check the bushings, for now i put less agressive wheels with spacers and stock springs
      04-27-2018, 06:01 AM   #15
M54E85
M54E85's Avatar
Drives: E85
checked on the hoist yesterday none of the bushings are torn but rear suspension is fully adjustable camber and toe so will be taking it to an alignment
      04-27-2018, 04:13 PM   #16
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
Not sure about your model car but I know the rear trailling arm bushing (RTAB) on the M and M3 go bad very quickly. It is #4 in your diagram.
CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights
      04-30-2018, 02:41 PM   #17
The HACK
The HACK's Avatar
1821
THIS.
      05-12-2018, 06:54 PM   #18
markos_z4
instagram : https://www.instagram.com/markos_z4/
markos_z4's Avatar
Netherlands
64
Drives: BMW Z4 Coupe 3.0si 2006
maybe your Trailing arm is bend i had the same issue with my right front wheel my KING PIN was bend . . . maybe you car has hit a road curb
front king pin :
follow me on instagram:www.instagram.com/markos_z4/
