03-10-2013, 02:27 PM | #1 |
Rep 832
OEM brake specs?
OK, just trying to figure out where my pads and rotors are at. Can someone tell me:
1) What's the minimum recommended pad thickness front and rear (Z4M) 2) Maximum "lip" on the rotors before I should be looking to replace them. Front rotors have a 0.019 lip at present. Thx |
03-10-2013, 02:45 PM | #2 | |
M = Midlife Crisis
65
Rep 2,006
2006 Z4MC - #LL93158
03-10-2013, 03:10 PM | #3 |
Rep 2,138
Drives: Me
It's not a 'lip' spec, but a overall rotor thickness specification.
As stated above, the minimum rotor thickness is stamped on the edge of the rotor. Normally, for the Z4M OEM rotors (ATE), the minimum front thickness is 26.4mm and the rear thickness is 18.4mm OEM rotors start out at 27.2mm and 19.6, respectively. |
03-10-2013, 03:11 PM | #4 | |
Rep 832
I know the wear sensors would let you know when they are toast but I was wondering how close I am getting to that point. I have the wheels off now and just bled the brakes but wondering if now is a good time to do the brakes or if I am good for a while. For the rotors, funny...I wasn't thinking of thickness, I was more concerned about the lip. I should have thought of that...brain fart. Thanks for the reminder. |
03-10-2013, 04:11 PM | #5 | |
M = Midlife Crisis
65
Rep 2,006
03-10-2013, 05:55 PM | #6 | |
Car Geek
3626
Rep 3,594
03-10-2013, 05:58 PM | #7 |
Rep 2,138
Drives: Me
That is entirely possible. They might be making them a little thicker now??
The new Zimerman fronts I received have exactly the same dimensions of the ATE's |
03-10-2013, 07:03 PM | #8 | |
Rep 832
Funny though, the numbers that are stamped on the rotor hats do not match up to anything relevant to these numbers. |
03-10-2013, 07:10 PM | #9 |
Rep 11,667
Interesting.... I always went by the specs on the hats.
03-10-2013, 07:18 PM | #10 |
Rep 832
03-10-2013, 07:28 PM | #11 | |
Rep 2,138
Drives: Me
"36K miles, 22 track days and my rotors are still at 26.9mm and 19.0mm." |
03-10-2013, 07:32 PM | #12 |
M = Midlife Crisis
65
Rep 2,006
Me too - but I'm about 28K miles...
03-10-2013, 08:19 PM | #14 |
M = Midlife Crisis
65
Rep 2,006
Brakes on these things are crazy good - BBK has bling for sure...
03-11-2013, 07:25 AM | #15 |
Rep 12,565
You'd be surprised how many USED BBK's I show up on classifieds, you could easily snag one for half price. Check m3forum and bimmerforum (race parts and brake classifieds).
03-11-2013, 07:32 AM | #16 |
Rep 2,138
Drives: Me
Now I have a question.
If you buy a used BBK, how do you know they are good? Do you have to search for a rebuild kit? Do you have to rebuild it? I am not adverse to using a 'second hand' brake system, but how do I KNOW it's good? |
03-11-2013, 12:58 PM | #17 | |
Rep 12,565
The only parts I'd get new when buying a bbk is stuff like new crush washers, new bolts for brackets, etc but all that stuff is relatively cheap. |
