12-17-2008, 09:09 AM | #1 |
Rep 1,262
HELP! DICE installation....
anyone done this? the instructions are for the radio with CD carousel, i just have the head unit and single CD. the instructions have no picture and have me scratching my head.... plus, i know NOTHING about audio, electrical...any help would be HUGE.
TIA A |
12-17-2008, 10:16 AM | #2 |
My favorite sign.
169
Rep 4,333
Did a quick search in the DIY section...
Did you see this thread? http://www.zpost.com/forums/showthre...highlight=DICE
12-17-2008, 12:30 PM | #3 |
Rep 18,846
Drives: BMW
What part are you stumped at? Removing the radio?
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
12-17-2008, 12:35 PM | #4 |
Rep 1,262
i saw that... looks like the trunk.
this is the set-up i got...the two big connectors on the left look like they should fit together, but that doesn't make sense to me that they would just connect back to each other ... how does this thing connect to my radio.... and the smaller plug (10-pin) looks like it connects to the DICE unit. and the blue connector is obvious as to where that goes... the instructions are pretty useless to me, they don't show the large connector... i'm hoping Tom at EAS will help out. |
12-17-2008, 12:57 PM | #7 | |
Rep 4,365
12-17-2008, 01:06 PM | #8 | |
Rep 1,262
matter of fact.... i am looking at the installation guide, and under 'integration kit contents'.... and the cables are different than what i am holding...hmm. |
12-17-2008, 01:52 PM | #9 |
Imola Lover
26
Rep 749
It would appear the cable is this item here: http://www.europeanautosource.com/pr...roducts_id=665
I've never used or seen any Dice product before and have zero knowledge of it. But from looking at pictures, it would appear you need to do the following: 1 - unplug factory cable (xxx) from back of radio 2 - plug male end of dice cable into xxx 3 - plug other (female with blue rectangles) end of dice cable into back of radio where xxx was originally plugged into. 4 - plug remaining pigtail from Dice cable into Dice unit.
12-17-2008, 01:56 PM | #10 | |
Rep 1,262
12-17-2008, 02:48 PM | #11 | |
Rep 18,846
Drives: BMW
AtoB, I'll be giving you a call soon to follow up.
12-17-2008, 05:02 PM | #13 |
Rep 274
Drives: 2010 128i Conv.
Anxious to see how it works for you. I believe I warned you last week to do your homework before buying the DICE.
Tom is a good man, I believe, and will help you all he can. |
12-17-2008, 08:24 PM | #14 | |
Rep 1,262
there is only so much asking and research i could do... it was time to take the plunge... tom called me and answered all my questions (thank you tom), and it was a cinch... the only issue i had was that the instructions were not the correct set which was confusing the hell out of me. after tom explained it to me, it all made perfect sense. all-in-all the install took me 20-30 minutes, and the DICE works perfectly. i love it! |
12-17-2008, 09:26 PM | #16 |
Rep 1,262
this system plugs into the back of the radio, the DICE unit and cables i secured to the brace support below the radio. then i just snaked the cord for the iphone down into the glovebox....i'll be adding a mounting kit in the glovebox to secure the iphone... finally i have a use for the glovebox
12-18-2008, 02:32 PM | #17 | |
Rep 274
Happy to hear it worked out for you!!! |
12-18-2008, 02:40 PM | #18 | |
Rep 1,262
