07-23-2010, 02:00 PM | #1 |
Rep 1,543
Intermittent Rubbing Sound
I get a rubbing sound that I believe is coming from the rear driver's side. It's periodic with vehicle/wheel speed. By that, I mean that the frequency with which the little "shik, shik, shik" sound occurs gets faster as I speed up. The best part, is that it's intermittent. It seems to most often happen after I've made a right turn.
When I first noticed it (last fall), I brought it in to the dealer and they didn't find anything. They also couldn't replicate it. I'll be taking it back in once I get my Jeep back from getting some work done but wanted to get your thoughts on what it might be. I've popped the car up on jack stands and removed the rear wheels just for a visual inspection and didn't notice anything unusual (e.g. brake heat shield bent). The scary part is that, now that it happens more, it is sounding list it might be metal on metal.
- Jeff
bosstones' flickr |
07-23-2010, 02:20 PM | #2 | |
Guilty as Charged
Rep 56
Do you notice it more when you are turning in one direction vs the other?
07-23-2010, 03:19 PM | #3 |
Rep 1,543
Happens more after a right turn. I hate intermittent problems!
- Jeff
bosstones' flickr |
07-24-2010, 11:35 AM | #4 |
Car Geek
3627
Rep 3,596
I had this (or similar) issue on my Z4M. It turned out being a very small rock that had made it's way between the brake backing plate and brake rotor to lodge inside the parking brake drum.
