      09-15-2014, 09:49 AM   #1
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
While drying my car yesterday...
...I was drying the doors/mirrors, closing the doors a few times to get any water out of the doors and mirrors. It struck me that since our mirrors fold upwards, maybe I can drain any water out of them by folding them. Eureka....or more like "why didn't I think of that sooner".
Any other car rinsing/drying tips out there specific to our cars?
      09-15-2014, 10:01 AM   #2
Spedracer81
Drives: Z4MC
I use a backpack plower to blow the water out of all the crevices, makes drying a little bit easier..
| 2008 Interlagos Blue Z4MC |
| AA Tuning | RPI Scoop | H&R Sport Springs | Sportline CS 16 CSL Wheels | Magna Flow Custom Exhaust |
      09-15-2014, 11:38 AM   #3
Seattle135is
Drives: 2015 M4
2007 335i  [0.00]
2005 SL 55 AMg  [0.00]
2007 Porsche 997 Turbo  [0.00]
Wash it, take it for a high speed burn, then do a final wipe off - may not work too well on darker colors (possible streaks), but certainly works well for Space gray!
2018 R8 V10+ - Ara Blue/Gray
2022 MS Plaid - Red/White (Daily)
2021 Alfa Stelvio - Red/Black
2013 135is - LeMans Blue/Gray
2003 M5 (56k miles) - CB/Black
      09-15-2014, 02:21 PM   #4
chickdr
Drives: 2006 M Roadster
I use a blower too. Great for getting the heavy water off before a final towel dry.
      09-15-2014, 02:32 PM   #5
gas-can
Drives: 2006 3.0i Roadster
elerner- I'm intrigued cause the mirrors always hold water which later drip and dry, but won't the folder mirror act like a cup? or does the water have a way to pass through to the other side (ground)?
and Seattle - you don't get any swirlies when you come back later to dry? I'm worried the dust that will glue itself on during the drive will then scratch the finish when you wipe down later... maybe swirls aren't as apparent in silver!
-gc
      09-15-2014, 02:58 PM   #6
NickyC
NickyC's Avatar
17424
After washing my car, I always take it for a 1-2 mile trip around the block. This blows all the water out of the cracks, and only takes a minute or two to wipe the car down one last time. Good tip. ;P
      09-15-2014, 03:56 PM   #7
Nate4641
Nate4641's Avatar
Drives: '07 M Roadster
I wash the car with the mirrors down then while drying I rotate the mirrors to drip the water out.
I also do a final rise by taking any attachments off of the hose and just let the water flow out of the hose at normal pressue. For the hood I have the hode at the front of the car and have it push water up over the hood so a thick layer of water is there and found that I have less water to dry up because the bigger mass of water pulls almost all of the water off of the car. A little hard to explain, but basically a more gentle and thicker flow of rise water leaves less water drops/spots than spraying the car.
      09-16-2014, 08:16 AM   #8
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
genius
      09-16-2014, 08:22 AM   #9
elerner61
elerner61's Avatar
157
-gc
Yes, when folded up the trapped water drains out from around where the mirror is hinged.
      09-17-2014, 09:54 PM   #10
Francisco4
Drives: 2007 3.0si Z4 Manual
What do you guys use to wipe/dry your cars?
FDR
      09-17-2014, 10:48 PM   #11
NickyC
NickyC's Avatar
17424
FDR
Absorber.
      09-18-2014, 12:17 AM   #12
StickMon
StickMon's Avatar
Drives: 2006 MR
Yep. "The Absorber".
Maybe it's not the best thing for the finish, or preserving the wax, but I have hard water, Interlagos Blue, and the humidity here rarely gets above the teens.
You want to see a guy move fast. You should see me drying it before it dries itself and gets spotted.
      09-18-2014, 05:23 AM   #13
2006E85
2006E85's Avatar
Puerto Rico
Drives: 3.0si Roadster
2006 BMW Z4  [0.00]
My Z is black and it will spot very easily, I mostly wash the car at night or early morning. I dry it with two Microfiber Towels. (One in each hand) wringing them at every section.
      09-18-2014, 07:38 AM   #14
Huz-Z
Huz-Z's Avatar
Would it work better to fold them up right away?
Huz-Z
      09-18-2014, 08:04 AM   #15
Spedracer81
Drives: Z4MC
I bought like 40 micro fiber towels, after blowing off the car...I probably use 20+ drying off the rest..then use quick detail while drying sometimes..when dirty toss them in a bucket and wash them to use again next week...
      09-18-2014, 11:14 AM   #16
elerner61
elerner61's Avatar
157
I've got two of the waffle texture drying towels that I use. One is from Meguiars that is very thin that I use for the first drying pass, the second is a really thick one from Autogeek.net (http://www.autogeek.net/cobra-guzzler-hd-towel.html).
      09-18-2014, 02:45 PM   #17
dreamingat30fps
Drives: Miata, Cayenne, Model 3, F350
I finally got my retractable compressor hose installed on the ceiling in my garage so I now use that for everything. Drying the car, detailing the interior, tires, sweeping the garage etc. It's a great easy upgrade to the garage.
      09-18-2014, 05:44 PM   #18
Westersund
Westersund's Avatar
Sweden
496
Drives: BMW
And the debris that get stuck on the car will get rubbed into the paint and might cause micro scratches. No thanks...
      09-21-2014, 06:07 PM   #19
gas-can
elerner I just tried your tip today and it worked brilliantly.
The residual water that used to creep out of the mirrors slowly after drying the car always bugged the hell out of me. Quick flip and all of it drained out like a charm.
If you were down here, I'd buy you a beer!!
Thanks again,
-gc
      09-22-2014, 07:08 AM   #20
ssummers
Drives: 2005 Z4 3.0
When I wash the car I use the backpack blower to dry it.
Recently I've started using Chadwick's triple play, I wash the car far less often now. It's great stuff, highly suggest it if you haven't tried it.
      09-22-2014, 02:24 PM   #21
M-Power M3
Retrograde
M-Power M3's Avatar
18
Drives: Bagged Z4
Genius tip OP! Don't know why I never thought of that haha.
I have an air hose connected to my tank in the trunk and usually use that to blow out water from the crevices.
Bagged e85 Z4 | www.ogretrograde.com
Bagged TT 225Q SOLD - e46 M3 SOLD - W202 SOLD - e46 325i SOLD
      09-22-2014, 10:04 PM   #22
wasupdu
wasupdu's Avatar
Drives: Z4 3.0, CLS63 AMG
I have soft water running to the hose that the cars are washed, so that's the first step that helps. Second, only if you wax your car regularly: This will cut your dry time in 1/2. Take the attachment off of the hose and let the water run over each panel and depending on the wax you've used (I've been on a Blackfire Black Ice kick) you'll need very little drying (30-45 sec tops).
2005 BMW Z4 Roadster 3.0 - Black Sapphire with Red Extended Leather / NAV / Premium & Sport Pkgs / 19" wheels / M steering wheel / Xenon
2013 Mercedes CLS63 AMG
