09-17-2014, 07:20 PM | #4 |
Rep 335
How did you like these coil overs? How was the ride? Handling? Noise? Quality? Could they be lowered enough? Was the 10k/12k spring rates the right choice? Would you buy these again? I'm considering H&R, Voigtland, and these BRs. The BRs are the most adjustable in terms of damping rates (32 settings), and come with camber plates and are pretty cheap. Did you find yourself using the adjustments or were they all pretty indistinguishable.
Thanks! |
09-17-2014, 11:40 PM | #5 | |
ホットドッグ
Rep 69
The quality is also great and as long as you install everything correctly, they should be quiet. The ride is pretty stiff but you can adjust the dampening to your preference. My buddies and I have used BC for years and have no complaints. Plus you can always get replacement parts from BC. This is the lowest they go (non-extreme drop):
09-18-2014, 01:20 AM | #6 |
Rep 335
Thanks for the info! It looks like that will be plenty low enough for me. I'm surprised they make even lower drops. You'd be scraping the mud flaps in the rear!
09-18-2014, 01:28 AM | #7 |
ホットドッグ
Rep 69
Np
