10-29-2015, 07:53 PM | #1 |
Rep 588
Drives: 2007 Z4M Coupe
TPMS
So I recently had front tires put on the M. When I left the shop the tpms light was still on. Pulled over at a gas station and made sure that 31psi was in all four tires.
Hit the reset light. Still comes on. I would drive it for a bit, light goes off, then the light starts blinking again and then solid. I would reset it a few more times and the same process would happen. A friend of mine said to put 34 psi in the tires. Went to a gas station again and put 34 psi in the tires. The tires were still at 31 psi so no air loss has occurred in the tires. Tried to reset the light again and the same scenario happened. Wondering if this has happened to anyone else. Wondering if I should go back to the shop and get the tpms checked out.
2021 m240i on order
10-30-2015, 12:02 AM | #2 |
Rep 817
My car did this when I bought it from the previous owner. It ended up being a connection issue with the wiring in the car. In my case, the wires carrying the TPMS signal from the receiver in the wheel well to the computer were shorting out (the shielding had melted above the rear muffler). I fixed the wiring and it was golden.
So, you might not have a problem with the TPMS. It could be the wiring running from that wheel well to the computer. |
10-30-2015, 09:24 AM | #4 |
dances with roads
4722
Rep 4,096
10-30-2015, 10:11 AM | #5 |
Rep 2,866
One of your TPMS may not be working properly. This happened when I had a temporary wheel installed on my car without a TPMS - It will blink for a while and then stayed on solid.
10-30-2015, 12:55 PM | #6 |
Rep 2,138
Drives: Me
If you have access to... or know someone that does.. or a shop who has... the INPA or Reingold software, then you can tell immediately if it is a wheel sensor, specifically which wheel or a TPMS (DSC) control unit issue.
Your TPMS wheel sensors are only rated for a battery life of 10 years. There is many reasons why they do not last that long. |
10-31-2015, 01:03 PM | #7 |
Rep 2,866
Slightly off topic. If you have to put new TPMS, do you have to program the car to look for the new TPMS?
10-31-2015, 03:49 PM | #8 | |
703
10-31-2015, 06:19 PM | #9 |
Rep 2,866
Thanks. I'll look for OE when I need a new set since they're not that much more than aftermarket
11-04-2015, 02:17 PM | #10 |
Rep 588
So I went back to the tire shop today. They checked out the sensors. All the sensors are reading fine. He put the system back in to "learn" mode. And he said yeah the tire pressure is a little high (because i put 34psi in) but thats alright. The light still goes off. What does that mean?
2021 m240i on order
11-23-2015, 03:17 PM | #11 |
Rep 588
Took back to the tire shop for the 3rd time today. Same thing. Nothing is faulting. The pressure was a little low but not terrible. They filled up all tires to 30psi. I got the light to reset off when I was sitting there.
When I start driving down the road after 5 minutes or so the light starts blinking again. Then stays solid. I'll reset it off again and the same process happens over and over again. So frustrating.
2021 m240i on order
11-26-2015, 11:43 PM | #12 |
Rep 588
So I think I'm starting to realize that at least one of the TPMS is failing. They weren't failing before I took it to the shop. Ugh. Whatever. Just frustrating. Is there any way to see which sensor is gone? I really don't want to have to replace all of them.
2021 m240i on order
11-27-2015, 09:17 AM | #13 |
Rep 2,782
I would look into converting the TPMS to monitor wheel speed sensors instead of the TPMS sensors, like the 2006 cars.
11-27-2015, 10:36 AM | #14 | |
Rep 2,138
Drives: Me
Why? |
11-30-2015, 02:29 PM | #15 |
Rep 904
Along those same lines, batteries on these sensors tend to last longer in cold climates and fail earlier in warm climates. Steenos lives in TN, so he's better off replacing all 4 now.
12-08-2015, 09:31 AM | #16 |
Rep 588
Fuck. haha
2021 m240i on order
12-12-2015, 08:59 AM | #17 | |
Rep 747
◙ Shane
12-12-2015, 05:59 PM | #19 | |
Rep 2,782
The TPMS sensors are added cost and weight, and they can be damaged during tire changes.
12-18-2015, 03:29 PM | #20 |
Rep 588
Continental Extreme Contact DW
2021 m240i on order
12-18-2015, 05:15 PM | #21 |
Rep 516
Drives: E85 Z4M, F82 M4
Sorry to hear about the TPMS issue. How do you like the tires so far? I had a set on my old 328i and really liked them. They are the front runner for my new spring rubber at the moment, so interested to hear your thoughts. Thanks.
12-19-2015, 10:42 AM | #22 |
Rep 35
I have a 06 Z4M and just purchased new wheels and tires. I explained to discount tire about the sensors and I need them transferred. They informed me on my model I don't have sensors but more of a indirect system. I didn't believe them so when the tire came off I inspected it and they were right, no TPMS and my light never illuminated. I'm really happy with new wheels and tires with no mods or tuning.
