05-31-2011, 11:14 PM | #1 |
Rep 420
Questions: inspection 2 / Battery replacement
Hi folks, my 06 M Roadster has reached inspection 2, but it is out of the maintenance warranty and they are saying I should have the valve adjustment done. The car has approx 44K miles on it. Does this sound right, or can I hold off on this?
Also, they are trying to kill me with the battery, saying it has to be a special one and installed by the factory...do they need to program the ECU with the battery or can I install one myself? I've searched and searched, but am finding a variety of results... |
06-01-2011, 01:07 AM | #2 |
Rep 969
Install the battery yourself. I just did might and it's just a simple drop in solution. Dealer told me the same thing and then tried to charge more $500 for the battery change (LOL - f^&* ridiculous - not that I would ever have them do it anyway).
Not sure about valve adjustment, but I believe you have sometime. I'm about the same mileage however and haven't done mine yet...
911 Carrera project car
Previous: E92 M3 ZHP - Sold E86 Z4M - Sold E36 M3 - Sold |
06-01-2011, 01:15 AM | #3 |
Rep 1,663
You do want to do the valve adjustment if it hasn't been done. Some people on here have had minor adjustments necessary, others have had to re-shim most of the valves.
06-01-2011, 09:32 AM | #4 |
Rep 1,224
IIRC, Mike Miller addressed this in the last issue of Roundel. For the newer models, programming is required for a battery change. For our E85/86 cars it's not required.
06-01-2011, 10:59 AM | #5 |
///M-fanatic
193
Rep 3,885
To hell with stealershits and their ridiculous prices. If you want OEM battery, get it from Tischer BMW (GetBMWParts.com). It's the cheapest OEM parts supplier online that I know of.
The battery swap is definitely a level 0 DIY job. Should only take 5-10 minutes at most. Valve adjustment is highly recommended. It's a performance motor so it's best to keep it running in tip-top shape at any given time, to the best of your ability. I'd try and find an indy (independent) BMW shop and save a little on labor as compared to the stealershits. |
06-01-2011, 05:45 PM | #6 |
Viper Driver
36
Rep 1,311
^+1. valve clearance checks and required adjustments accompany every inspection, which averages an interval between 22,000 to 28,000 miles dependent on lifetime fuel consumption of the engine. 44,000 miles is fair for inspection 2 and the requisite valve clearance check and adjustment. i would seriously give thought to having an independent accomplish inspection 2 as not only will it be significantly cheaper (i paid $695 for my inspection 1 vs $1400 the dealership was asking), but u can research for the best/most trustworthy bmw specialist indy to do the valve adjustments.
fwiw, i did not require any shims/adjustments for my valves at 23,200 when i had my inspection 1 done. |
06-02-2011, 03:30 PM | #7 | |
Rep 112
06-02-2011, 05:25 PM | #8 | |
704
As for the battery, WTF? Needs no programming--what a scam! Just buy your own and slap it in. Here's a thread with options on purchasing a compatable battery for a good price from your typical auto-parts places. No big deal here. Man, that stealership sure lives up to the name. Battery Thread |
06-02-2011, 09:55 PM | #10 |
your average JAMF
3101
Rep 4,094
For our cars - you're right. We're lucky. But as mentioned above, Mike Miller just wrote about this in Roundel, and it's 100% true that a whole slew of recent models, and he listed all of them, do require that the car be "reprogrammed" to accept a new battery. Typical BMW overkill with electronic crap. Glad that our cars are immune from much of this stuff.
'21 M2 Comp
'19 Golf R |
06-05-2011, 06:02 PM | #11 | |
704
06-06-2011, 10:26 AM | #12 |
Rep 317
I just did both of these. The service cost me 1100 at an independent shop that I trust. I had them do the entire service, there are parts of it you could do yourself and save money (trans and diff fluid, in cabin airfilter maybe more).
I got a direct battery replacement from o'rileys autoparts. I believe it was around $140 installed by me... Advance auto also had a listing, but it DID NOT FIT. |
