06-17-2011, 09:12 AM | #1 |
Rep 160
Drives: 2007 BMW Z4 M Coupe
What are the most cost effective ways to increase HP?
The other day I was browsing through some websites and some had ESS turbo kits etc. All fine and dandy, but all those options ran in the thousands of dollars. Was wondering what are some cost effective ways to increase power or speed?
Exhausts? Cold air intakes? Cams? Reducing weight? |
06-17-2011, 09:51 AM | #2 | |
Rep 112
06-17-2011, 09:54 AM | #3 |
Rep 6,870
Best bang for your buck will probably be the turbo or nitrous route. Things like exhaust and intake may make minmal hp gains but they are mainly for sound more than anything.
06-17-2011, 10:02 AM | #4 | |
Rep 160
So you're saying its better to spend 6-8K on a turbo charger than 2K on an exhaust system? |
06-17-2011, 10:04 AM | #5 |
instagram 997turbotom
286
Rep 7,377
first of all, there is no turbo kit for the z4m on the market yet, even though 2 are in development.
Bast bang for the buck are euro headers, at $850 + ess tune ~$600, which will net you about 25RWHP, and lots of usable torque. Cold air intakes don't make power on this car, and even though cams make 15-20hp at the wheels at best, they run about $2k+ to install. Mufflers save weight, but don't add much power Weight reduction wise, you can start with a deka etx14L (~40lbs off), 18" forged wheels that are 18lbs each vs stock 25lbs (check **********s.com), and seats $1000 for 40lbs savings each Either way, if you're like most power hungry people, after you do all these little things, you'll get bored of them, and eventually get an ESS VT2-500 supercharger ($11k 420rwhp, 300 rwtq, or the upcoming HPF turbo kit (~$15k for 420rwhp, 320rwtq) Most people who take the slow upgrade route say "shit, I already spent $10k on my car if you add up all the little shit, I could have just bought a supercharger for that much and made a lot more power"
06-17-2011, 10:16 AM | #6 | |
Rep 160
That's the problem; you get used to the power you have and then you "feel" like your car is slow. For example, I started out in a MazdaSpeed3 GT turbo which had 264HP and 280ft/lbs torque and I thought "wow" this has a ton of power when I was driving it the first couple weeks. I got bored of it and decided I needed more power so after test driving the Z4M, I thought "Wow, now this is REAL HP since it was NA and had no turbo lag" at 330HP and 262ft/lbs torque and now a year after getting the Z4MC my brain is telling me "I need more power, this doesn't feel that fast anymore". |
06-17-2011, 10:38 AM | #7 |
Rep 1,662
Buy a mustang. upgrade parts are much cheaper.
There is no cheap way to make more power for our cars. Exhaust is mostly for sound, stripping weight from the car will make it feel faster, but may impact it's usability if you strip it down to it's core, or expensive if you are replacing with light weight materials. Ebay headers and a tune are probably the best bang for your buck. Beyond that you're talking diff change and F/I.
Current: '13 E92 M3 Euro Delivery Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3 |
06-17-2011, 11:03 AM | #9 |
Rep 2,128
If you're not going to shell out for forced induction, don't bother fiddling with the engine at all, imo. Changing to 3.91 or 4.10 gears is the best bump in outright performance. Aside from that, I'd only do headers and exhaust.
06-17-2011, 11:09 AM | #10 |
Rep 4,320
Drives: '07 Z4 M Coupe
Euro headers and a tune. Intake and exhaust will sound great - but don't do much for performance on the Z4M.
06-17-2011, 11:34 AM | #11 |
Rep 784
Drives: 2011.5 E90 M3
Get a CF hatch, hood, and roof. mmmmm carbon fiber
06-17-2011, 01:36 PM | #12 |
Rep 6,870
Not saying its better, both cost a pretty penny. But bang for your buck, even though a turbo system may cost 2-3 times as much you will see noticeable gaines in power where as an exhaus system may sound great but probably is providing little if any power increase.
06-17-2011, 01:52 PM | #13 |
Rep 10,309
Drives: A///MERICAN!!!
This is a thread about being cost effective
Best bang for your buck would be cheap headers. Bimmerworld sells some for 5 or $600 and the fit seems pretty consistent. They are, however, best paired with a tune, or you're looking at relocating your secondary O2 sensors. With a tune, you're looking at maybe $1300-$1500 in parts before labor if you can do the headers yourself. Diff is expensive and labor intensive, and not as DIY-able as headers (though if you feel comfortable, go for it), and I would be wary of the shorter gearing if you do a lot of highway driving. |
06-17-2011, 01:56 PM | #14 | |
Rep 784
06-17-2011, 03:58 PM | #15 | |
286
Rep 7,377
and yes
06-17-2011, 04:44 PM | #16 | |
707
If we're talking cost effective as in lowest spend for a measurable increase, then headers, O2 relocation, and a tune. Like many have already said, the path to more power always leads to one wanting more, and I've seen many people start off with the "cheaper" exhaust/tune approach only to spend far more in the end.... |
06-17-2011, 07:02 PM | #17 |
Rep 10,309
^^^Agreed, but again, most looking for the most cost effective way to increase power are also not likely to be willing to drop 8k on a supercharger. Hell, the true most cost effective way could be swapping in a supercharged LSx...it may cost 20k but you could be putting down 700+ hp...but I digress...
I've been casually kicking around the idea of going with bimmerworld headers and standard epic tune, especially as I change my mind about exhaust every time I log on youtube. For $1300ish factoring in everything, and doing the work myself, I would consider this more cost effective when factoring in everything, such as installation costs and potential future problems (not to say supercharging is unreliable, but there is that general rule more pressure = lower longevity) |
06-17-2011, 07:45 PM | #18 |
M = Midlife Crisis
66
Rep 2,006
Buy a faster car - been there done that...
2006 Z4MC - #LL93158
06-17-2011, 08:05 PM | #19 |
Rep 2,703
Drives: 2009 335i - Sport PKG
Guys, save money for rainy day
06-18-2011, 01:00 PM | #20 |
Rep 2,128
Gears would be ~$1500-2000 if you buy the gears and have a shop rebuild your diff; only going the Dinan route is expensive. The 3.91s are fine for highway driving - on my runs home to KY I have to remind myself to use 6th.
06-18-2011, 01:35 PM | #21 |
Rep 10,309
Now I'm curious...what gears are you running? So you just swapped out your gear set...did you get "grenade" insurance lol? Diffs online's cheapest new diff is a factory type LSD and with 3.91 or 4.10 gearing runs about 2k after a core return...but their 3.91 gearset is only $135...Also what are you turning at 70-75 with 3.91?
06-18-2011, 07:14 PM | #22 | |
Rep 2,128
I love the upgrade, though. |
