      09-15-2017, 11:26 PM   #1
dre99gsx
Drives: 1994 Toyota Supra
Rear wing without front splitter
Anyone here road coarse with just the addition of a rear wing (no front splitter)? How does the z4 coupe feel at top speed and corner entry? Being that are cars are 50/50 weight, I curious if addition of only a rear wing made the car that much lighter up front, or if our front end is already pretty good at downforce in stock form?
      09-16-2017, 12:47 AM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
It definitely needs front aero to balance it out.
I have run many variations of front and back setups.
...& that's why I ended up designing my own front end; APR splitter alone wasn't enough.
      09-16-2017, 08:01 AM   #3
Mirko
Mirko's Avatar
yup , i agree. I found adding canards helped front end a little, especially going into turns with speed. Would need slightly bigger ones to be honest but near impossible to find at reasonable price to test fit.
I am running rear varis diffuser and a gts wing in the back along with apr and canards in the front. Pretty good stability and can feel the aero grip. I'd say a slight rear bias but car is pretty stable.
To answer your other question, stock front end and rear have slight lift at speed. There are some threads about how much buried around here somewhere. I found slightly lowering with coil overs helped front end lift. I felt floaty in the front under stock suspension when above 150kph.
      09-16-2017, 09:22 AM   #4
dre99gsx
Interesting. Obviously I'm trying to avoid going front splitter, mainly for daily driving sake (speed bumps, driveways, etc), and the uncertainty of how much splitter is enough.
Guess you're somewhat referencing this thread:
http://www.m3post.com/forums/showthread.php?p=22089354
      09-16-2017, 11:25 AM   #5
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
With your skills you could make one ala M4 GTS that slides in and out.
      09-16-2017, 11:29 AM   #6
dre99gsx
Don't give me anymore ideas!
      09-16-2017, 03:21 PM   #7
Steeler
Steeler's Avatar
2428
Just to add my .02 to this discussion.
No road course for me but I have had a chin spoiler/air dam on my non M for 3 years and this year I add the Skyer rear lip spoiler and side skirt extensions. I do experience front end floating at "highway speeds" now that I did not experience before. I can't see the extensions causing front end lift so it has to the the rear lip pushing the rear down.
I wish there was a decent splitter option for the Pre facelift front fascia.
      09-16-2017, 07:22 PM   #8
3002 tii
3002 tii's Avatar
2282
It's going to push in the corners... no need to go crazy, most racers use Home Depot diy splitters with great results.
Believe or not I actually think the OEM aero bumper is somewhat functional and doesn't upset balance of the car such that you need a rear wing.
Follow for latest mods
      09-16-2017, 08:14 PM   #9
dre99gsx
Ok. Not an ideal splitter for all intents and purposes, but I just built my own for the heck of it. 1/4" thick lexan, carbon fiber wrapped.
Also, my wing is mounted fairly low, more like a spoiler, and is adjustable. I will see how it does at NJMP in two weeks. This was a FT86 SARD wing (got it for a steal) that I custom mounted with brackets which fit on the edges of the hatch. No holes drilled!
I know there are ways to improve on what I have, and I could have kept going, but I'm not a fan of the large roof-height wing nor long 4" splitters with canards. I'm going for subtle right now.
Also in the works is a custom rear diffuser similar to FancyWide, but integrated with my current rear diffuser. I doubt the diffuser will do much, but I have many holes/pockets underneath the rear which need to be filled.
      09-16-2017, 10:01 PM   #10
3002 tii
3002 tii's Avatar
2282
Very nice work. Which club you running with at NJMP?
      09-16-2017, 10:02 PM   #11
dre99gsx
Delaware PCA
      09-16-2017, 11:34 PM   #12
3002 tii
3002 tii's Avatar
2282
Delaware PCA
Nice one of the best clubs.
      09-17-2017, 09:26 AM   #13
pcube
pcube's Avatar
58
Drives: Z4MC, G20 320i
What just happened. Just a day ago, seemingly casual question was asked. And suddenly out pops a custom front splitter.
Can you post more pics of the your custom wing mount? Specifically directly from the rear, and also the mounting points with the boot raised. I'm shopping for a wing, have a few options in mind but am really holding back due to the need to drill holes.
      09-17-2017, 10:13 AM   #14
dre99gsx
I work fast With HPDE coming quick, need to have something to experiment with. The splitter is by no means correctly done. It is probably too narrow, and there is no damn to help direct high pressure air around the bumper to the sides.
I was going for this look and 'effect' with just enough rear spoilage to help reduce lift, not necessarily add downforce:
Hopefully the downforce really isn't that much more than before, reducing the need for a proper front spoiler. I'll know by this track session, and have the winter to mull over a more complete design.
I'll get some photos later tonight.
      09-17-2017, 01:20 PM   #15
dre99gsx
      09-18-2017, 09:41 AM   #16
pcube
pcube's Avatar
58
Thanks for the pictures!
      10-16-2017, 02:47 AM   #17
Over it
Mad Man
Drives: car
Very nice. Love the Fab work
      06-16-2018, 02:46 PM   #18
Z4C17
Drives: Bmw z4 coupe
I wish I can get one of these wing for mines.
      06-16-2018, 09:07 PM   #19
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
This. If anything these cars need more help with grip in the front than the rear.
Top Down 365
Vanne1620.50
      09-01-2018, 06:57 PM   #20
Z4M06
Drives: 2006 black Z4 M
I hate how the steering wheel feels lighter during turning with throttle.
