      09-20-2011, 10:47 PM   #23
VinnieAces
VinnieAces's Avatar
Drives: Imola Red Z4MC
2006 Z4 M Coupe  [8.00]
Hm, could be worse I suppose, thanks for the help BTM!
anyone confirm if that truly is the fuel regulator?
///M - Some Mods 'N Stuff
      09-21-2011, 08:29 AM   #24
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
I'd try a tank or two with some techron concentrate before I blew dough on an unconfirmed part.
      09-21-2011, 09:04 AM   #25
Etch52
Most roads are too short and too straight
Etch52's Avatar
Drives: 2007 M Coupe - Premium Package
Prime the pump ..
Originally Posted by Caddyshk View Post
In addition turn the key to position 2 and delay for a few moments before cranking.
Priming the pump this way solved any cool weather start-up roughness I encountered with my M-Coupe.
2010 Honda Pilot Touring, 2013 328i xDrive Luxury Edition, 2007 M Coupe
      09-21-2011, 09:55 AM   #26
VinnieAces
VinnieAces's Avatar
how long do you keep your key in position 2 for? I've left mine in that position for 15 seconds one time and it did not seem to help
also i just filled using Shells 91 which has no ethanol in it, going to see if this helps
      09-21-2011, 10:00 AM   #27
Drives: M2 Comp
Just a few seconds (5) is plenty.
      09-21-2011, 10:43 AM   #28
johanness
Drives: 2008 Z4MC
Yep. Chevron's 94 contains zero Ethanol & the most Techron. Although I doubt that's going to sort out the S54's cold-start moodiness. I think it's the nature of the beast.
On a side note, when you use the iPhone app for this site... avoid the "&" symbol and your message should be ok. Seems that interrupts things fwiw
      09-21-2011, 11:36 AM   #29
BTM
Drives: A///MERICAN!!!
Yea I wouldn't jump into that right away - sometimes I just like to play easter hunt on realoem.
The only other part on there I found that sounded close was a control unit for about $270 I think. But it sounds like your car just doesn't like the cold and didn't like it more than usual that day. Hopefully it was an isolated occurrence.
      09-21-2011, 11:49 AM   #30
costa316
Drives: z4m
So I monitored the problem over the weekend, and everything was fine. I filled up the tank yesterday, and as soon as I started the car the RPMS's shot up and then down...didn't stall, but almost did.
      09-21-2011, 12:42 PM   #31
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
That 94 octane made me think ... do most of the folks with the cold start issue use > 91 octane fuel? I only have 91 octane available. I've never had any cold start issue, never had to prime my fuel pump either, just jump in, start it up and drive. Valvetrain takes a few minutes for the valves to stretch but nothing more than 30 seconds and the idle is butter smooth.
      09-22-2011, 02:26 PM   #32
VinnieAces
VinnieAces's Avatar
Update: Didnt have any early classes this morning so i started the car around 2:00PM when it was nice and warm outside, RPM's did not drop nearly as much, barely a studder in fact so I am going to assume it is indeed the engine being very Cold in the morning that is causing this behaviour.
I'd still like to hear of your experiences though and if there are any problems with the fuel regulator pump.
      12-03-2011, 12:24 PM   #33
beta
Drives: 2006 M Roadster
I'm having the same issue intermittently. Start up the car and the rpms drop then stabilize. It has been very cold lately. Anyone found any solutions? normal?
      12-03-2011, 12:38 PM   #34
VinnieAces
VinnieAces's Avatar
mine still does this once in a while, not as much since switching to Shells 91 compared to Sunoco/Petro Canada's 94
      12-03-2011, 01:00 PM   #35
aerobod
Car Geek
aerobod's Avatar
3626
Drives: Caterham R500, M2-G87, Macan S
I find mine seems to stutter a bit after starting when the temperature is in the -10°C to +5°C range. If I press the throttle down 10mm or so before turning the key, it never has a problem. At temperatures from -35°C to -10°C it doesn't need any throttle, but it does sound like a can of bolts being shaken around when starting it below -20°C
      12-03-2011, 01:30 PM   #36
danlauz
Drives: z4m 2007+x5 2009+330 cic 2003
My 2007 z4m was at the dealer for almost 2 weeks for the same problem... I have the last update but, after changing the MAS, it did not fix the problem. The software is up to date. They told me they know when its colder the melange do not have enough gaz (air is denser). They cannot do anything other than suggest me to give some gaz on before starting the car....BM do not expect to make a new software update as the car is not sold anymore. They also told me they looked at the spark plug and, i could change them. They have seen sometimes it fix the problem . Mine is 36000 km.
      12-03-2011, 01:48 PM   #37
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
Yup! In addition turn the key on to pressurize the fuel system prior to cranking.
2006 Z4MC - #LL93158
      12-03-2011, 01:56 PM   #38
danlauz
Mine is sleeping for winter since this morning. Will see her back in april...
Ps... My car was fully reprogrammed and never had Inspection 1. Asked for the valve adjustement and, they refused. If i need this to be done, i will ask Caddyshk for help...
Warranty will be done in january during the sleep...
      12-03-2011, 02:33 PM   #39
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Ian is the Man - I'm the sous mechanic; essentially I enter data into the PC, hand him tools and open beer!
      12-07-2011, 01:37 PM   #40
beta
This didn't help at all. When it's really cold it still will drop the rpms for a sec then come back. Besides this I'm seeing no other issues.
      12-07-2011, 05:11 PM   #41
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Try fuel as others have suggested.
