09-20-2011, 10:47 PM | #23 |
Rep 1,603
Drives: Imola Red Z4MC
Hm, could be worse I suppose, thanks for the help BTM!
anyone confirm if that truly is the fuel regulator?
///M - Some Mods 'N Stuff
09-21-2011, 08:29 AM | #24 |
Bad Lieutenant
233
Rep 3,517
I'd try a tank or two with some techron concentrate before I blew dough on an unconfirmed part.
09-21-2011, 09:04 AM | #25 |
Most roads are too short and too straight
Rep 66
Drives: 2007 M Coupe - Premium Package
Prime the pump ..
Priming the pump this way solved any cool weather start-up roughness I encountered with my M-Coupe.
2010 Honda Pilot Touring, 2013 328i xDrive Luxury Edition, 2007 M Coupe
09-21-2011, 09:55 AM | #26 | |
Rep 1,603
also i just filled using Shells 91 which has no ethanol in it, going to see if this helps
09-21-2011, 10:00 AM | #27 |
Rep 11,667
Just a few seconds (5) is plenty.
09-21-2011, 10:43 AM | #28 | |
Rep 1,739
Drives: 2008 Z4MC
On a side note, when you use the iPhone app for this site... avoid the "&" symbol and your message should be ok. Seems that interrupts things fwiw Last edited by johanness; 09-21-2011 at 11:17 AM.. Reason: iPhone crap |
09-21-2011, 11:36 AM | #29 | |
Rep 10,309
Drives: A///MERICAN!!!
The only other part on there I found that sounded close was a control unit for about $270 I think. But it sounds like your car just doesn't like the cold and didn't like it more than usual that day. Hopefully it was an isolated occurrence. |
09-21-2011, 11:49 AM | #30 |
Rep 79
So I monitored the problem over the weekend, and everything was fine. I filled up the tank yesterday, and as soon as I started the car the RPMS's shot up and then down...didn't stall, but almost did.
09-21-2011, 12:42 PM | #31 | |
Bad Lieutenant
233
Rep 3,517
09-22-2011, 02:26 PM | #32 |
Rep 1,603
Update: Didnt have any early classes this morning so i started the car around 2:00PM when it was nice and warm outside, RPM's did not drop nearly as much, barely a studder in fact so I am going to assume it is indeed the engine being very Cold in the morning that is causing this behaviour.
I'd still like to hear of your experiences though and if there are any problems with the fuel regulator pump.
12-03-2011, 12:24 PM | #33 |
Rep 1,663
I'm having the same issue intermittently. Start up the car and the rpms drop then stabilize. It has been very cold lately. Anyone found any solutions? normal?
12-03-2011, 12:38 PM | #34 |
Rep 1,603
mine still does this once in a while, not as much since switching to Shells 91 compared to Sunoco/Petro Canada's 94
12-03-2011, 01:00 PM | #35 |
Car Geek
3626
Rep 3,594
I find mine seems to stutter a bit after starting when the temperature is in the -10°C to +5°C range. If I press the throttle down 10mm or so before turning the key, it never has a problem. At temperatures from -35°C to -10°C it doesn't need any throttle, but it does sound like a can of bolts being shaken around when starting it below -20°C
12-03-2011, 01:30 PM | #36 |
Rep 134
My 2007 z4m was at the dealer for almost 2 weeks for the same problem... I have the last update but, after changing the MAS, it did not fix the problem. The software is up to date. They told me they know when its colder the melange do not have enough gaz (air is denser). They cannot do anything other than suggest me to give some gaz on before starting the car....BM do not expect to make a new software update as the car is not sold anymore. They also told me they looked at the spark plug and, i could change them. They have seen sometimes it fix the problem . Mine is 36000 km.
12-03-2011, 01:48 PM | #37 |
M = Midlife Crisis
65
Rep 2,006
Yup! In addition turn the key on to pressurize the fuel system prior to cranking.
2006 Z4MC - #LL93158
12-03-2011, 01:56 PM | #38 |
Rep 134
Mine is sleeping for winter since this morning. Will see her back in april...
Ps... My car was fully reprogrammed and never had Inspection 1. Asked for the valve adjustement and, they refused. If i need this to be done, i will ask Caddyshk for help... Warranty will be done in january during the sleep... |
12-03-2011, 02:33 PM | #39 | |
M = Midlife Crisis
65
Rep 2,006
12-07-2011, 01:37 PM | #40 |
Rep 1,663
This didn't help at all. When it's really cold it still will drop the rpms for a sec then come back. Besides this I'm seeing no other issues.
12-07-2011, 05:11 PM | #41 |
M = Midlife Crisis
65
Rep 2,006
Try fuel as others have suggested.
