07-07-2011, 12:15 AM | #1 |
Rep 291
What is this part in the intake?
When replacing the air intake filter on my 06 z4m, i noticed that there was a black filter looking piece on the top piece of the intake. Should this also be replaced?
07-07-2011, 10:13 AM | #4 |
Bad Lieutenant
233
Rep 3,517
If you do pull it out, and you decide later you want it back, you will have to buy the entire housing. It's an emissions control filter, yanking it out does nothing but there are some reports of idling issues, etc.
07-07-2011, 10:19 AM | #5 | |
Rep 291
http://bimmerfest.com/forums/showthread.php?t=157656 There was actually a service bulletin about this that says that the "activated charcoal filter" can cause idle issues |
07-07-2011, 12:15 PM | #6 | |
Rep 1,097
07-07-2011, 12:41 PM | #7 | |
Rep 11,667
It does go back in on the clips if you're careful taking it out.
07-07-2011, 01:16 PM | #8 |
Bad Lieutenant
233
Rep 3,517
Yeah, those clips are like fisher price plastic. Completely worthless "mod" though
07-07-2011, 01:19 PM | #9 |
Rep 10,309
Drives: A///MERICAN!!!
07-07-2011, 11:57 PM | #10 |
Rep 820
Drives: 2007 Z4MR silver grey
This thread prompted me to do a lot of reading on this subject. The guys over on the M5 board all swear by this, claiming a smoother power delivery and better breathing engine, and a little better gas mileage to boot.
John |
07-08-2011, 08:48 AM | #11 |
Rep 1,772
Drives: 2007 Z4M Coupe
I did that after a member on here told me about it. I didn't notice anything special. Anyone else done it yet?
07-08-2011, 08:52 AM | #12 |
Viper Driver
36
Rep 1,311
if i'm remember this correctly, someone accomplished a dyno with and without the charcoal filter and noted a negligible +1whp improvement most probably due to slightly improved air flow.
07-08-2011, 09:26 AM | #13 |
Rep 10,309
Most I noticed is a little more aggressive sound
07-08-2011, 09:54 AM | #14 |
Rep 2,431
yank it, it's supposed to clean up the air/fuel that comes out of the intake after you shut off the car...it does nothing for you when the motor is running
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm Gone:z4m, boss 302, c6 z06, m6,z3m |
07-08-2011, 10:35 AM | #15 |
Rep 291
I'm confused. Why does BMW say that this can cause idle issues? Is this bs? Note the "Activated carbon filter removed or modified"
"SIB, Subject: S54 Service Engine Soon Light Illuminated: FC 174 and 175 Fuel System Diagnosis. Applicable to E46 M3 with S54 engine and E85/E86 with S54 engine. With the Service Engine Soon Light illuminated the customer may complain of: Rough idle Engine idle observed higher than normal (approx 900 RPM) Hesitation while accelerating Poor fuel economy Cause: Induction system diffuser missing Activated carbon filter removed or modified Aftermarket unapproved air filter/cold air kit Modifications made to any part of the induction air path. NOTE: Air path disturbance is defined as any modification to the induction system from the point where the air enters the front of the vehicle to the cylinder head intake ports." |
07-11-2011, 10:52 AM | #16 | |
Rep 10,309
Aside from the initial starting up right after removing it, my car runs/idles without problems. |
